Most likely a distributor failure. Have you checked to see if the ground side of the coil is working? Put your testlight alligator clip on B+ and probe the ground wire at the coil. If while cranking it flickers, chances are you have a bad coil assuming you are checking spark at the coil. If it doesn't flicker, then its most likely an igniter failure.
