1972 Datsun 510 (56k best of luck)
Looking good there. What's next on the list?
Enjoy her, getting running better. She drives, but not perfect. Need to check the clutch slave cylinder, think it has a slight leak or still has some bubbles. And need to work out the engine, she doesn't run like top, almost backwards. Starting from a cold engine she starts and idles at "warmed up" idle (750rpms), doesn't like to have the throttle touched, and only puts out about 12 volts out of the alternator. After a few minutes and starting to warm up, she jumps up to 1800 rmps, 15.5 volts out of the alternator, and can be driven, but spits and sputters a little bit.
