18'' Rim Fitment
gjmoreo
Blue MP3
Can someone please help me out with a fitment issue?
And yes, I have read RISHIES STICKY ... so dont tear me up.
I want to know what are the possible sizes that I can fit on my Mp3 for 18'' rims.
I need to know ..
OFFSET MIN: ?
OFFSET MAX: ?
Distance between lug holes: ?
LUG PATTERN: 5 lugs
Width of rim in inches: ?
THANKS SO MUCH.
my msp is 5x114.3
in 18" the minimum offset is a 45 as a rule with 48 being recommended, i believe with lower offsets, such as 42, you run into an issue with rubbing in the rear only
(this is all for 7.5" width)
I just got some 18"s for my msp in a 42 mm offset, with 215/35 parada spec-2s.
I had spool springs, but for some reason on my msp the rear spool springs lifted my car significantly so I put the stock springs back int he rear. I have only rubbed a couple times, and as far as I know, only in the left rear.
The first time I rubbed and only time I am positive that i HAVE rubbed I had taken a left hand corner at a pretty decent speed, and was switching back on a right hand banked, sharp corner which apparently has some kind of a sunken spot in it, and I rubbed when I hit the sunken spot....
rubbing looked pretty minimal and im sure a little fender shaving or rolling would fix it
I agree, but I never rub (thanks to a little negative camber in the back) with my +45 offset, and I am tucked!
