no i am deffinatly going to try to go no less then 48mm offset and hope to get a lighter and wider 17" wheel. did some researching in tires weights as well and the stock rsa is actually a lower weight tire most perf tires are 23-25lbs the rsa is 22... found some toyo's at 20lbs that seem to rate pretty good think i am going to try those out. if i get those enkeis it would make for a 7-8lb reduction at each corner with 225 vs 205 wide tires as well. i think that is going to make a huge difference losing that much unsprunp weight and gaining that extra width, as well as the lowering springs and new rear sway and front strut bar i need to put on still, should be a whole new car!
