Thanks for all the info. I want to do this on my newly LEASED CX-9. Will there be a problem when I go to return it back to the dealer? Is there a way to revert back to original condition?
HI...I'm doing this on a 2015 CX-5. On the flashlink app, I see no bypass tab or remote starter tab. No tabs at all. This seems out of date. Anyways, I pick my vehicle and options and hit 'FLASH'...and that's it. I don't have the options to see 'C1' or anything like that or the remote starter tab to 38.5 - no idea what that is. Moreover, I can't seem to locate a proper installation guide for my make/model. Any thoughts? thanks.
Has anyone run into an issue of not getting the solid blue light after holding down the reset button the first time you connect power? I have double checked the two connections, cut the yellow line and rerun the procedure three times and it keeps flashing red/ orange. No solid blue
Not only do you plug the Mazda (steering column) plugs into the T-Harness, you also then have to plug the 2 remaining plugs from the t-harness into the steering column."[/COLOR]
Yup, there are two connectors under the dash (both white, adjacent to each other). I disconnected these two connectors from the vehicle harness and plugged them into the (2) T-harness spots. I then plugged in the the two connectors from T-harness into the slots under the dash (Basically working like a bypass). When pressing down the button, the only physical connection from the T-harness and the Fortin box was the 6-pin connector. Did I miss a step somewhere?
That sounds right. The only other thing I can think off is that the Fortin instructions says to press and hold the button before and while connecting the 6 pin harness (white connector). Maybe if you don’t hold it before connecting it changes something. I would retry that if you have not already done it.
If that doesn’t work I would contact Fortin, you may have a defective harness or module, but they would be able to tell you. There isn’t a lot else that can go wrong prior to that step.
Curious if anyone else has heard of or done this?Thanks to all the great advice in this thread I too have successfully installed the EVO-ONE in my 2019 CX-9 GT. I re-used a Tele-Connect / Autolink cellular remote start device from my previous vehicle which also had a Fortin unit installed and can start my car from my cell phone. This is a feature that one you have you can't live without.
Thanks for the ideas! I tried to call Fortin and they'd asked me to talk to the folks who sold my kit. I got mine at Amazon so that's kinda no-go. I'll try and reach out again
What was the issue and how did you fix it?Came in to update all that I got mine to work successfully. Like many on here posted, it was bone easy to set this thing up in hindsight. It works so well, I am even angrier that Mazda couldn't implement this
