15x6.5 +38 will it fit msp
hukster00
06 GG Evo 9
hi, has any one tried 15's on msp ? and would 15x6.5 +38 fit it, if not what offset do we need ? thanks
Yes it will fit but that is the lowest offset you can run on the MSP according to discounttire. I have +40 offset and I get occasional rubbing but the tires on them are also just a little bigger than stock too.
With that +38 offset I'd definitely recommend a tire with a smaller diameter than your stock ones otherwise I can guarantee you will rub in the back. I'm speaking from experience.
ok, thanks,
i just need them for the track , i be using 225/50/15 so if it rubs little bit i dont mind
