15K Factory Service (Turbo Vehicle's at 7,500 Mile Intervals)
pcpower
Is it true that I need the following for my MS3 at 7,500 miles? Sounds expensive. Or.... could I just get away with an oil change?
Replace engine oil and filter Rotate tires Lubricate all locks / hinges Inspect the following:
Automatic transmission
Axle & suspension parts
Brake lines & cables
Brake pads, rotors, drums & linings
Cruise control vacuum hoses
Drive shaft boots
Exhaust system
Differential oil
Steering gear and linkage
Steering linkage ball joints
Front suspension ball joints
Manual transmission oil
Perform Mazda Full Circle Inspection
Model Specific. Prices vary
They are just "inspecting" which really amounts to nothing. My dealer pretty much does it every oil change for free.
They don't do any of those. "Inspect" means nothing as they just look at your stuff and doesn't even do it half of the time.
change the oil and listen for noises that the car shouldn't be making. if you hear anything ask about it. "inspection" at dealerships often amounts to making sure no parts are hanging off
i skipped my 7500 miles check up and gonna do the 15k check up at the dealer or somewhere cheaper. 7500 miles is basically an oil change and some small inspections which you can do it yourself.
check your car manuel and it will tell you what you should do at what miles.
Wow I haven't looked in the manual at that. So we are supposed to change the trans oil at 7500? And diff oil? Hmm..weather has been getting cold and my trans is getting clunkier and clunkier. bad..I'll just pay for trans and diff oil changes.
No. Not change it, inspect it.
all that does is give the dealer (really just the tech and his service writer) a little more time to scrutenize your car. if they want more money out of you (which is what they're doing with these "inpections" in the first place) they will take the time to check out your car.
getting it up in the air is an excellent oportunity for the tech to find a "potential" problem and report it back to the service writer. then it's the service writer's job to sell you more work that needs to be done. for example, if while under your car the tech sees that one of your exhaust hanger rubber mounts is cracked eventually the service guy will say "your exhaust mounts are cracked and will need to be changed or the exhaust could get damaged."
then basically you make your decision and buy another one and the labor it takes to install it, or say "F you" and let it go
the key is for them to in a way make some things a little overblown so it seems like a "fix it or it will break soon" problem for you. when in fact if you could get under your own car and just merely look at all your stuff just like the tech does you can make the decision on your own. you could even use a forum to post up pics or problems and see what everyone else says before having the dealer dig into your wallet, but that's your choice
all i know is i got lied to by the dealer once for some brake check, which is sooooo easy to do when they're rotating the tires anyway. well, my brakes apparently needed to be changed within the next like 5k miles they said, but when i bought the pads to do it myself and got the wheels off there was still like 8/32'' left. and that is waaaaaaaaaay more than 5k miles
long story short (too late in know) just get under your own car and check stuff out yourself, or pay 250 for someone else to tell you things that you don't really know for sure if they are telling you the truth or lying about
+1 They're most likely to do something wrong (wrong type/amount of oil), something left loose that was fine before they touched it.
You're better off having a tech you trust do this stuff. I take mine to a quick-lube place I've dealt with for years. They're all car-guys and take good care of my rides ('course I'm right there, watchin' every move). The dealer is not likely to let you watch up close, citing "insurance requirements".
This thread caught my eye today and I looked up the normal and severe service interval in my Alldata system. It was quite close to what the OP listed, I intended to put up a copy here but ran out of time today. Most of the items listed are inspections that should be getting done with every oil change at a reputable facility. It certainly shouldn"t be $250 for any Mazda product.
It seems a surprisingly high percentage of posters have some real trust and/or confidence issues with the place that works on their car. You really need to ask your friends/family who they like and "shop around" with little stuff until you find somewhere/someone you're comfortable with. Not all garages are scam/con or rip-off shops.
Visual inspections mean just that. When you fill a glass with water you stop adding water based on visual clues, not weight nor volume nor frequency or miles or whatever, you just look at them and see if they look as they are supposed to. Of course, you have to know what they're supposed to look like first; if you don't, there's a shop near you that does, much like there are places that do taxes and surgery and chrome plating, all things I can pay someone to do for me if I don't know how to do.
Wishing everyone out there finds a mechanic they can consider a friend.
My dealer charges $69 for the 7500 mile factory service.
You guys are gettin ripped off! ($69 is even too much for a glorified oil change)
At 15k miles, odds are none of those items will need attention. Never hurts to have a look, but ethically, they shouldn't charge you for that inspection- they should be doing most of that every time they change your oil.
I worked at an independent Exxon station as a gas jockey, tire monkey, oil change clown... and I quickly learned to inspect most of those items while the oil drained from the car. When it's on a lift, the inspection is simple.
Here's what to look for:
Rotate tires
Lubricate all locks / hinges - We did this at customer request, no extra charge. White lithium grease on hinges, very light spray of graphite powder into door locks.
Automatic transmission - Check fluid level on dipstick, look for discoloration of fluid as an indication of breakdown.
Axle & suspension parts - Visual inspection, look for bent control arms, etc. or hydraulic fluid leaking from shocks/struts.
Brake lines & cables - Look for rust, abrasion, wear, and signs of fluid leakage.
Brake pads, rotors, drums & linings - Check pad thickness, make sure rotor wear is relatively even, not deeply grooved.
Cruise control vacuum hoses - Check ALL vacuum hoses under hood & make sure they are not brittle, dry rotted, cracking, kinked, etc.
Drive shaft boots - Rotate drive shafts & look for cracks. Squeeze to make sure they are pliable, not brittle, dry rotted, etc. ***VERY important for FWD cars.
Exhaust system - Look for loose/broken flanges, hangars & clamps, excessive rust, holes in system.
Differential oil - Check level, make sure oil is not milky or runny.
Steering gear and linkage - Look for visual signs of wear, grab & tug to make sure everything is tight.
Steering linkage ball joints - Look for visual signs of wear, grab & tug to make sure they are tight.
Front suspension ball joints - Look for visual signs of wear, grab & tug to make sure they are tight.
Manual transmission oil - check level & make sure it hasn't gone milky, etc.
***Manual transmission & differential oil usually don't have dipsticks- you just remove the filler plug & stick your pinky in, about one knuckle deep. It should get oil on it. If not, you may be low.
And once you've done this a few dozen times- especially at a dealership where you're only working on one make of car, it should take you 5 minutes under the car & another 2-3 above. It can all be done in the course of a normal oil change. NOT worth much, if any, extra charge.
they wanna charge me 320 in NY for 15 k checkup...and its bulls*** they told me....change air filter/oilchange/change wiperblades/visually inspect things/check tire pressure/check trans fluid
now instead of this im just gonna change some things myself...im full stage 2 i really dont want to go over there... first off i use 5w-40 castrol syntec not there crap oil, and i just bought ford motorcraft XT-M5-QS for tranny fluid...i already got new rainx windshield wipers..and im ordering rims n tires for the summer and prob new break pads...
you can go to a shop and they can visually inspect things for free with the cost of a oilchange/rotate tires or maybe like 10$ extra at mosttttt.
__________________
