Hey guys just picked up a set of rota slip streams for 180$ without tires. Have any of you guys used rotas without problems? Rims are 15x6.5 40mm offset so they should stick out a little further than the stock 45mm offset but i got alot of room to fill. I also bought some 54.1mm to 67.1mm hub-centric rings. I have eibach drop spring also. Probably anout 1.5" drop. Currently running 195/65 15 without rubbing. Could i just reuse these tires?
