15"x6.5" Rota's tire size?
HA-Y-N
2003 mazda protege lx
Hey guys just picked up a set of rota slip streams for 180$ without tires. Have any of you guys used rotas without problems? Rims are 15x6.5 40mm offset so they should stick out a little further than the stock 45mm offset but i got alot of room to fill. I also bought some 54.1mm to 67.1mm hub-centric rings. I have eibach drop spring also. Probably anout 1.5" drop. Currently running 195/65 15 without rubbing. Could i just reuse these tires?
In case anybody is actually interested in this thread i put my rotas on today. Everything fits good. I was on a budget so i got two 205/60 for the rear and 195/60 for the front. The rear are just about maxed out and do rub if im driving stupid fast but they filled up the wheel well perfectly and give it a more sporty/beefy look. I didnt get my hub rings but so far no vibrations even going 80+ mph. So bottom line the popular rota slipstreams fi great. All you need are long acorn nuts so you dont damage the rims while removing/installing. I also noticed the engine pulls harder probably because my 15" steelies weighed a ton. Over all i am stoooked with my rims. I will post pics as soon as i figure out how.
Congrats on the new wheels. If the pics are on your computer, you can just attach em. Click "go advanced" at the lower right, then look for the manage attachments button.
Any way to post from a mobile device because i dont have a computer at home? Only got an iphone.
