15 mm spacers with steelies..
saxmanbrad
2008 MS3 Black Mica
Okay guys, here goes.
I need some opinions on the the use of my 15mm spacers with my winter setup. The spacers I have contain their own lugs, so the stock ones protrude a bit but fit into the recesses on the stock wheels. When I put on the steelies, (with spacers) the stock lugs protrude enough to not allow the steel rim to sit flush on the hub. So here's the question: Would you: (1) Ditch the spacers to make life easier (even they look great), (2) go through the hassle of taking them off every time I mount my winters, (3) cut the stock lugs so they don't protrude beyond the spacer. Not sure if choice three is such a good idea. Anyways, thoughts would be greatly appreciated.
