- 2001 Mazda MP3
the FCD is an overall bad solution to fuel cut. a proper remedy would be real engine management, not something that assists in blowing the motor like the FCD (under some circumstances)
heh. right, kiddo.jurgs01 said:Another blown motor with the Joep FCD. Just like to point out that almost every motor that has blown has a Joep FCD with no engine management. Sorry to hear about the car though. Build it up nice.
While this is true, you also have to consider I had my car boosting 14 or so before management was even an option. I think at that time, Linux was one of the very few to have a standalone, and that was even from an overseas company that didn't support the Protege at all (or so I think).pdhaudio83 said:the FCD is an overall bad solution to fuel cut. a proper remedy would be real engine management, not something that assists in blowing the motor like the FCD (under some circumstances)
Spooled said:Have you looked at the tops of the pistons yet? Bet there's detonation marks all over from running lean with that FCD at such high boost. That probably ate away at the rings, too. Better the rings than breaking rods.
So what are you going to do next? Engine management, internals, both? Good luck with everything!
