To flash, they mush be wired off of th ealarm itself, not the ignition harness although, if needed you can use that as its power, but you should be using the contant power I would think.matty00pro said:They're actually meant to flash/light only when the ignition is turned off. Do i need to use a relay, or can i just change the wiring around so they flash when ignition is turned off?
I have to assume then this isn't just an LED, there is a box with a circuit of some kind in it?matty00pro said:I believe it says that they can be installed with or without a alarm.
LED'S continuosly flash with engine OFF, continuosly ON optional
Red...*...12V+ battery
White....ignition........ (De-activates led's when 12v+ applied)
Green....12V+ positive (Turns led's ON constant)
Black.....ground
*=optional switch location
All these wires should be in the steering harness, so i can just tap into those right?
