mazdamastertech said:come on boys and girls, i have 2 motors on the shop floor, thanx to quick lube people leaving the drain plugs loose and falling out. i going to pull the original motor out and put in 1 of the other 1's. i don't want to tear up my good 1. the trans can any 1 say warrnty! it already needs sycrnos and i can get paid to put the lsd in. it should hopefully hang in 4 a couple of months or passes!! i do plan on briging a trailer or wrecker. my guess is going to be an axle to break. the main thing is to get the fuel right, it won't take being lean 4 long. the pcm is capaible of retarding the timing 20+ degrees. i can take the wds and capture the knock senser, the long fuel , short fuel trim, and 02 reading, and what else i can think of that is important. have some faith in ur mazdas!!!!!!!!!!!!
Yeah, I remember those engines. I even contteplated taking one off your hands when I was down there last month. But then, Asianhottie started some s*** with a tow truck driver! End of story!:mad:
