if you blow an engine and come back with anything short of an entirely forged setup, you're an idiot.mspeedpro said:droppin in a used motor wont cost 4000
If that's the case, you should do that before you blow your engine. (chair)mspeedpro said:id rather back off the boost a bit than use the oppurtunity to go all out, just my opinion
Then Im a total idiot for not having enough $$ to get the new motor forged.Pkay said:if you blow an engine and come back with anything short of an entirely forged setup, you're an idiot.
if you blow an engine and put a used engine back in the same setup that it was blown in, then yes you're an idiot.igdrasil said:Then Im a total idiot for not having enough $$ to get the new motor forged.
I dont understand. The motor can hold boost, mild boost.
You should look into water/alcohol injection. It will give you more margin for error.igdrasil said:Thats right, I blew my engine because of a bad tune....one pull was rich, next one was lean and boom.
I tried tunning 12psi without knowing much.
Now Im tunning pig rich. 5psi is almost done, so, next level will be 7psi and so on. By the time I reach 10-12psi again, I will have the $ for the forged stuff.
