Striker187
- 2008 MS3 GT
so you have to run extra injectors with the piggyback? also, does it have some kind of anti-stall feature so that it would be possible to use a bov w/o fear of stalling?
mp5jeff said:chrisjw85
why is you're friend running 10lbs on a wrx they run 14 stock...
Striker187 said:so you have to run extra injectors with the piggyback? also, does it have some kind of anti-stall feature so that it would be possible to use a bov w/o fear of stalling?
In order to supply the engine with enough fuel your only option is to run extra injectors with this setup.Striker187 said:so you have to run extra injectors with the piggyback? also, does it have some kind of anti-stall feature so that it would be possible to use a bov w/o fear of stalling?
MAF (mass air flow sensor)Larone said:What exactly is the difference in functionality between an MAF and a MAP? I know that for whatever reason with the MAF you need to recirculate, whereas with the MAP you don't have to. How do they work and what are the differences? Thanks.
Striker187 said:so where will the maf be in relation to everything else? it's obviously gotta be after the turbo, otherwise putting a bov before it doesn't make sense. is it before the throttle body and after the ic?
and the maf is 80mm correct? so would it be possible to fit this to say, spool's hardpipe kit where the piping is 2.5"?
Striker187 said:a map operates off the Manifold Air Pressure. so it's basically counting the air coming into the intake manifold. a maf counts the air coming in through the intake. thus, you can vent to atmosphere without stalling if your car uses a map since no air has been counted yet. that's why hondas can use bovs without any fuel adjustments.
You cannot manipulate the MAF to " see less air". You can vary the voltage the MAF will output. Thats all. With the stock mazda ECU this is a problem if the voltage variation is too great in closed loop.Emode said:is there a way you can manipulate the amount of air seen by the MAF if you were to trick the temp. sensor into seeing the air warmer than it actually is, therefor reducing voltage?
igdrasil said:I think it can be done....im just guessing, but you can use the TPS information and vacuum inside the manifold and before the tb?
I dont know if any ems can do it that way
