09 RX8 Remote Starter?
09RX8
Can I install or have installed a remote starter for my 09 RX8? If so, is there a preferred make/model?
Thanks
Thanks
Mazda make a factory option automatic start to suit the RX-8. They also quote its for the AT version only buts just because you have no clutch over-ride function.
2 versions available are remote start unit + remote start & security system unit.
2 button (start/stop) or 4 button (start/stop lock/unlock) versions
Part# C907 V7 620 = 4-button unit
Part# F152 V7 630 = RX-8 adapter unit
Part# C906 V7 620 = 2-button unit
Part# F151 V7 630 = RX-8 adapter unit
Just get you local Mazda guy to order those parts in & then adapt the supplied harness to your OEM harness & it will all work.
REgards
what he said.
also, to expound upon the AT only thing, the reason why they say that is because your car could just take off with the remote start if you leave the car parked in gear and use the remote start. it has happened to a friend of mine already.
For Aftermarket id go with Viper. and the new MT cars most of them come with a neutral switch you can tap into so the car wont start while its in gear
