I installed a class 3 hidden hitch and also purcahsed the quick connect wiring harness that is plug and play to the stock tailights.. I have done these wiring before and has been simple, just plug into the taillight wiring harness and done. For some reason the CX9 kit states I need to run a Power wire all the way to the battery.... I have never seen this before.
My question is:
The 09 GT is from the factory set for the trailer kit, It is not an option. (Only option is the hitch and wiring) Is there a power wire already in the rear of this car so I do not need to run the wire all the way to the battery?? maybe pre wired from the factory so dealers or the factory do not have to run this wire.
Thanks
Kevin
My question is:
Thanks
Kevin
