08 Mazda 3 mp3 deck in MS3
bdillon
2008 mazdaspeed 3
This is probably something I should try and figure out on my own but I have a family member that has an 08 Mazda 3 with the 6 disc mp3 deck and I have a ms3 that does not have it so i am wondering if anyone knows if it will fit in my speed3 and will it hook up and work?! Thanks for any help
most likely, yes
electrically almost certain, trim may not match
it takes like 30~45 sec to pull the stereo
give it a shot
Since they have the Mp3 deck I assume they have a '08.5 model. The mp3 HU was available pre-'08 as a dealer-only accessory but didn't come standard on any model. As part of the '08 mid-year refresh all HU's became Mp3 capable.
Technically speaking there's a slight pin difference between the two.... I believe the main harness went from a 32 pin to a 30 pin connector. That said other members have successfully swapped between pre/post refresh HU's without an issue.
One thing to keep in mind is the '08.5 one has additional ports on the back of the HU so it's possible to hook up the ACI, and ipod module, and sirius vs. the older model which can only have sirius or ipod but not both. If you don't use any of those then it shouldn't matter.
Other than that like tddvrrn noted as long as both are bose, or both are not bose there won't be an issue with the swap.
