08 GT Squeak from front suspension when going over bumps
2017 Mazda CX-9 Grand Touring
Ive seems posts on lubing struts/bump stops but does anyone have video on this? The squeak is annoying and I really don't want to pay the dealership to temporarily repair this.
Ive notice the same squeaking noise when travelling at low speeds over bumps the noise appears to be coming from the front end . Does anyone have any advice?
I don't think there are any videos because it is very simple to do.
1. Jack the front tires off the ground.
2. Pull up rubber boot on strut
3. Apply lube to the steel (silver colored) shaft of the strut.
When you lift the rubber boot up, you will notice the rubber bump stop. Move it up the shaft to lube the shaft. Now hopefully you can read this post with a straight face with all the shaft and lube words.
