02 protege camber angles!
02protege...
02 protege I 4 2.0 L
does anyone know what ere the camber angles for an 02 protege???? my car is "eating" the stock tires on the inside of three wheels.... two in the front and left rear.... thans for having me in this forum.....
got to a shop... toe was off by .5 mm... you cannot even see that!!!!!!!!!!!!!!!!!! 2-morrow I'll be installing new tires and balancing/alligning my car... just the rear left tire was out of specificatrions regarding camber, the front where in the .48 degree measurement from the shopp manual...... i'll post after i replaced my tires.......
you also need to understand that just becuase its within "spec" doesn't mean its a "good" alignment. just make sure they get the exact same numbers on both sides.
