kulkarnipb
- 2012, CX-9 Touring
I have 2012 CX-9 AWD Touring.
While going through the forums, I realized that there are 2 ways to get the existing ATF out before pouring new in.
a) Removing drain plug as stated in - http://www.mazdas247.com/forum/show...luid-Changes&p=6326764&highlight=#post6326764
and
b) Using the Transmission connector return line as per -
http://www.mazdas247.com/forum/showthread.php?123855296-Home-transmission-flush-success
I am wondering - why can't I use both the methods like -
1. First remove ATF using drain'level plug.Fix Drain/level plugs back.
2. Pour the new ATF using fill plug ( exact quantity that I removed in step 1. )
3. Start engine and while engine is running, using Transmission connector return line, let the existing ATF come out and at the same time keep pouring new oil from fill plug . Try to match the quantity ( that is , whatever amount coming in, try to pour in approximately same ).
4. Once the Transmission connector return line starts throwing new oil, then stop the engine. Fix the connector line back. Pour little more oil through fill plug.
5. Drove CX-9 for a block or so 9 ( so that ATF temperature rises between 37 and 47 degrees Celsius) and then while engine is running, using level plug, remove excess ATF.
Are these steps good ? Does anyone sees any issue here .
Thanks in advance.
and
Thanks in advance.
