2013 CX-9 to 2020 CX-9 wheel compatability
2020 CX-9 GT
I'm picking up a 2020 CX-9 tomorrow(!). Selling my 2013 CX-9. I have GT trim (both 2020 and 2013) but picked up a set of OEM 18" wheels for winter use that fit the 2013 (i.e., swapping 20" for 18" in the winter). Will these wheels fit the 2020?
Solution
OEM specs for the 18" wheel on the 2013 CX-9 GT are as follows:
Tire: 245/60/18
Rim: 18x7.5 +45 ET
PCD: 5x114.3
OEM specs for the 18" wheels that come on lower trims of the CX-9:
Tire: 255/60/18
Rim: 18x8 +45 ET
PCD: 5x114.3
Both CX-9s have a center bore size of 67.1mm. 2013 OEM wheels/tires have an overall diameter of 751.2mm. 2020 wheels/tires have an overall diameter of 763.2mm. That difference will result in a 1.57% difference in speedometer readings between the two, but the difference is minimal (30mph with the 2020 wheels would actually be 30.5mph with the 2013 wheels, for example).
The 2013 wheels will fit just fine on the 2020. If you haven't purchased tires yet for the 18" wheels, you could do 255/60/18 and there would be no...
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
Tire: 245/60/18
Rim: 18x7.5 +45 ET
PCD: 5x114.3
Tire: 255/60/18
Rim: 18x8 +45 ET
PCD: 5x114.3
The 2013 wheels will fit just fine on the 2020. If you haven't purchased tires yet for the 18" wheels, you could do 255/60/18 and there would be no difference in speedometer readings.
Upvote 0
Solution
2020 CX-9 GT
Tire: 245/60/18
Rim: 18x7.5 +45 ET
PCD: 5x114.3
Tire: 255/60/18
Rim: 18x8 +45 ET
PCD: 5x114.3
Thanks. I should have been more explicit - I was planning on sizing up the tires. But wanted to make sure the fitment with the wheels was workable. Thanks for the response.
Upvote 0
Top
