Thanks for the first hand accounting on this. Are there specific grades more affected than others?Yes its a real thing. Our bulk supplier just had a price increase by 30% on all of our synthetics and has run out of a lot of bottled product. We buy it by the 55 gallon drum and that currently is less effected. GM and Ford are running out of ULV for the 10 speeds which is going to be an issue.
Mostly 0W- oils and atfs as it requires a higher quality base stock to meet 0W. For a variety of reasons I hope the situation resolves quicly.Thanks for the first hand accounting on this. Are there specific grades more affected than others?
I've been following this and I'd absolutely pick up at least another jug. My next change is in the fall and I've got 2 jugs stashed. That way I'm also covered for 2027. I expect this will take a long time to get resolved and with price increases already on group 3 base oils that most synthetics use I wouldn't expect it to be any cheaper for a while. As of a few days ago Walmart still had most everything in stock. I picked up my second jug of Mobil 1 ESP 0W-30 then. Mobil is having a $10 electronic gift card with purchase of many grades of motor oil. Now's the time to be getting it.I just did an oil change maybe 3 weeks ago now. Just picked up some SG1 gear oil, and am putting in an order for ATF FZ, just deciding how much to get.
Thinking maybe should get another 5 quart jug of 5w30 for the fall just in-case. At minimum save some money since it will probably go up.
