Need help, metal flakes in oil and oil burning
Yeah definitely interested to see how it looks after running that through and then seeing what you get at the next oil change interval.
I typically stick to 5k miles changes as I primarily short / city drive these days. Oil consumption is pretty normal occurrence so I'd wager over 7k+ miles, that 1.25 quarts isn't that unusual. I use 5w30 in mine and still from time to time add half a quart, give or take between changes.
Try using high mileage oil or additives. It can help seal up your engine and reduce consumption further
I am using high mileage. I have 153k miles on mine. Usually Castrol Edge or Pennzoil Platinum.
Has that helped with the consumption?
I would probably use some additional high mileage additives like liqui molys stop leak stuff, seal conditioner until it seals up
Yeah I think it has. These days I'm doing a lot of short trips / city driving so not the best.
