N7turbo
2023 CX-5 2.5T ... 2024 MX-5 RF GT
Yes, the car must be on the ground when you adjust the links to achieve zero preload before tightening them down with threadlocker. Now obviously you can't get under the front of the car while it's on the ground, so put it up on ramps. And note the following:Just to confirm the proper process, after you replace the end links while jacked up wheels off, do you then put the wheels back on put it on ramps and do the final adjustments?
Normally you'd do the very top nut first with the wheels off. Wheels back on, car is up on ramps, then you do the bottom nut. Then you work on the center section. Up front, once I was "done", I had to bring the car back down off the ramps, jack up one side and reach around/through my wheel (may be hard with stock wheels, in that case, take them back off) to get a better torque on the top jam nut on the center section. It's just not possible while laying under the car to get a good angle with your arms all the way up there.
And I definitely recommend pre-adjusting them so they are close to the final length as it will make your life much easier.
