Hey guys, been a while seems like..
Random question, has anyone noticed their CX9 sitting differently on a flat surface?
As the weather is warming up and spending more time outside, I noticed the driver side of the vehicle sitting lower than the right side. It's about 3/4-1 inch difference, which is noticable to the eye.
For context, I'm about 215lbs, family of four, wife is petite and my two kids are young. My 45lbs kid sits behind me and the 90lbs kid sits behind the passenger side, at the back.
I don't tow (no hitch) and I don't use this for work whatsoever. No tools or anything else left in the vehicle at any time, other than a snow brush, battery booster etc, battery cables etc.
I can take pictures, but thought it's odd but not uncommon based on a quick Google search.
Good day to all and blessings...
I'm curious as my cx9 is approaching 45k miles. I hardly use it and just completed inspection where i only put 1,867 miles from my last inspection last year, lol. I try to run it every 2 days since we had a bad winter thus far in my region. Mine is asking me to do an oil change on her which i dont think needs one but will just do so i guess to help keep all fresh.
Wanted to ask what other fluids could be due or recommended to change at this change? I heard perhaps a radiator flush may be a good idea and if do oem fluid would be essential i presume?
Swapped the battery out in Nov, 25 with a bj’s battery that turned out yo be inferior to the oem one. Gave warranty so planning to exchange it ot possibly return. Had it checked at autozone and it seems it doesn't recharge to full spec snd dont want a problem for when i need to use my cx9.
Thanks for much. I’ll definitely plan on getting the fl22 fluid then for the radiator flush. Prob try to order the fluids online from a Mazda dealer because my local dealer is more than expensive with parts and pricing. How many gallons did you use? I figure I would be ok with 2 bottles of the fl22?I think a coolant flush would be a good preventative measure. There was a TSB for plugged heater cores in some models up to 2019 MY, when Mazda switched the formula from 50/50 to 55/45 and changed the FL22 formulation to include more or better corrosion inhibitors. I would highly recommend OEM FL22 for that reason.
For ATF and transfer case/rear diff, I've read that some will do their first at 50k and then every 30-40k after that. I personally did my ATF and diff oil at 72.5k kms (45k mi) and I'll do both again at 120k kms (74.5k mi). I used OEM fluid for both as well.
As for the atf and transfer case fluid I’ll definitely look into those fluids also but outside my dealer.
Would ultimately have to source an alternate declarer to do the job as that would be out of my realm of handy if you will, lol.
How is your holding up? Still have your nice wheels I hope
