Slight shake in floorboards when idling in neutral
First time post. 2023 cx5, has cylinder deactivation. Bought new. 4cyl non turbo. Engine had an oil leak which was determined to be a hairline crack in the block. Engine replaced under warranty. When the car was returned we noticed a slight shake in the floorboards only when the car is sitting idling in neutral. Shop is not having luck locating the cause. Anyone had this problem or any ideas?
Where was the crack located?
First thing people will think is motor mounts. They need to be sitting right and torqued correctly under load. Someone who has actually worked with them could provide more info.
yes it was the rear main seal area, close enough to look like a rear main leak. The mazda tech did check the motor mounts and tried adjusting them but no change. The trans was removed once also when they were going to replace the rear main seal.
