N7turbo
2023 CX-5 2.5T ... 2024 MX-5 RF GT
Just 5W-30. Their blend is nothing special, either.What does Mazda recommend for the turbo?
Have always been glad I don't have to put up with that kind of crap. It truly makes a car a "consumable" item. There's got to be a better way!Washing the car.
Every several days, certainly within the week, since salt/brine has been laid down on the major streets. And whenever the weather turns a bit better for a day or two, it's a full wash with de-salting treatment (StarBrite's Salt Off). Nicely, the undercarriage has a decent Line-X treatment, so very little goes "ugly" under there, even with occasional driving along salted roads.
Won't keep every last bit of residue off the rig, but it sure helps.
This is a common problem when you let "someone else" do the install. Common solution is to get a piece of door edge molding and install it over the rough cut edge.Just got back from the dealer where they installed the Mazda auto dimming/Homelink rear view mirror and tow hitch. The tow hitch required cutting of the black plastic lower valence of the rear bumper. From a distance, doesn't seem too bad. Up close, not so sure. When I have more time, I might get up under the car to look at the cut out and see if there is anything I can do to clean up the edges of the cut plastic.
They didn’t add something like a piece of trim over the cut plastic? Thought they’d do something like a thin u-channel strip of black plastic or something to hide the toolmarks on the bumper.Just got back from the dealer where they installed the Mazda auto dimming/Homelink rear view mirror and tow hitch. The tow hitch required cutting of the black plastic lower valence of the rear bumper. From a distance, doesn't seem too bad. Up close, not so sure. When I have more time, I might get up under the car to look at the cut out and see if there is anything I can do to clean up the edges of the cut plastic.
I did and returned it. It prevents use of the cargo net and makes it harder to use the storage system. The four piece is better.I ordered the 3DMAXspider for the trunk. My bad
Pls post picture of bumper topper and comment on fit/quality.Installed:
VIOFO A229 plus to ‘25 CX5 Premium Plus
Had no luck getting the power using the VIOFO hardwire kit, so ordered a DONGAR 10-A adapter and installed to the back of the rear view mirror…so simple and works great for those of us that won’t use parking mode
Car came with low wall all weather mats which lacked coverage, upgraded to
3DMAXspider Kanu front and back, much nicer coverage and look
Order OEM truck liner, not a fan of the 4 pieces , wish I ordered the 3DMAXspider for the trunk. My bad
Tymate wireless TPMS
American flag license plate frame
Waiting for temps to increase before installing:
WeatherTech bumper topper
Lower front mesh grill
Door sill protectors
Fortin One car starter
you are doing alot to the 25' pp-nice....doesnt it have remote start from factory?Installed:
No remote start except via the Mazda-Connect spying app.you are doing alot to the 25' pp-nice....doesnt it have remote start from factory?
spying app? it works well for me....No remote start except via the Mazda-Connect spying app.
As long as you are O.K. with them tracking your every move and collecting tons of data on you.spying app? it works well for me....
That may be the case but they can use their cell data and not mine. We are on a metered data plan and in less than a week they used our entire allotment for the month. We deleted the app immediately.Just to be clear, they still collect data without the app.
It's just that the app expands on the kinds of data.
That's a whole lot of 1's and 0's transmitting back n forthThat may be the case but they can use their cell data and not mine. We are on a metered data plan and in less than a week they used our entire allotment for the month. We deleted the app immediately.
