BC Racing Coilovers before and after
Apparently the ultra low only affects the rears.
You are correct.
The rear spring perch like OEM doesn't hold the spring. The 2 and less ride height spring didn't have much safety factor in the perch. BC sent me the taller spring.
Looks great! I have BCS Racing on our 24 CX5. I only dropped it 1.5" front and 2" rear. "We" have issues parking and not putting the front on the curb. This was the happy spot.
I put adjustable lower control arms in the rear and adjustable camber bolts in the front. Alignment came back spot on.
Also replace the front and rear sway bars with Megan Racing sway bars and aftermarket end links.
It handles very well, especially making quick moves to avoid a crash. Driving down the interstate it's rock solid.
I am looking at BCS for my 24 CX5. Did you upgrade to the swift springs with them? In cars of past, I have, just wondering what your experience all around has been on the BCS...?
I didn't see that swift springs would a benefit on our slightly lowered, Daily Driver. They look like they are good for much lower cars.
We have about 18k miles on the system. They have performed flawless.
They are a performance mod. If you are expecting to behave like oem soft ride, you maybe disappointed.
Bump stop is harsh. If one hits a BIG pot hole and it bottoms out it is a wake up call. I like this "feature" to wake up my wife to avoid rather than blindly run over potholes. We have a set of light weight spun forged wheels. Big pot holesight damage them.
It's louder. I believe the top of the oem front struts are cushioned with a plastic material. BS Racing is an aluminum on aluminum. It makes more noise than oem. But performs much better than OEM. Agai. A trade off for performance.
So if you want performance they deliver. We have them on 4 out of 20 stiffness for my wife. Steering is quick and precise. Coupled with larger sway bars with urethane sway bar bushings. It's a performance upgrade.
If we put the shocks say on 15 clicks it would be a handler.
The front struta are lighter. Unsprung weight is a big deal for quick maneuvers and braking. Same deal with lighter wheels.
I changed the front brake pads and rotors, drilled and slotted the first month we got it. Oem squealed and dusted.This helps stopping quicker and not as likely to warp. My partner rides the brakes and warps rotors. I decided to start with upgraded rotors this time..
I hope this helps.
I hope this helps.
What pads and rotors did you install?
Put these on at 2500 miles. +18,000 now on the car. These have a look and work great.
Sourced from RockAuto.
I put R1 on all four corners of my 09 Odyssey Touring, along with braided stainless hoses.
I really like them. The stock Ody brakes are notoriously inadequate.
Can't understand why Honda didn't put the larger Pilot brakes on the Ody.
