2019 NA model original plugs with 57000 miles. Any tips on changing? Is this standard 5/8 socket?
Thanks
Thanks
Note to thread readers: there are instructions that say do not do this on Mazda engines with the type of plugs they use.I'm new to this platform as I bought my car last week. But I typically like to use a little anti-seize on the plug threads before installing them in the head.
Why?Note to thread readers: there are instructions that say do not do this on Mazda engines with the type of plugs they use.
I understand
You should not use anti-seize on NGK spark plugs because they feature a special trivalent plating on the threads, acting as a built-in lubricant and corrosion inhibitor, making anti-seize unnecessary and potentially harmful by causing over-tightening, leading to thread damage, shell stretch, or breakage. NGK plugs are designed to be installed dry to ensure correct torque and heat transfer, preventing serious engine issues like pre-ignition from altered heat ranges or stripped cylinder head threads.Why?
I haven't used NGK plugs before. Just looked up some info on them and anti-seize. Some are saying a small amount of anti-seize and hand tight isn't going to hurt anything. Comes down to what you're comfortable with.You should not use anti-seize on NGK spark plugs because they feature a special trivalent plating on the threads, acting as a built-in lubricant and corrosion inhibitor, making anti-seize unnecessary and potentially harmful by causing over-tightening, leading to thread damage, shell stretch, or breakage. NGK plugs are designed to be installed dry to ensure correct torque and heat transfer, preventing serious engine issues like pre-ignition from altered heat ranges or stripped cylinder head threads.
Ditto.NGK (the plugs Mazda uses) says don't use it, so it's best to skip it.
When changing my plugs, I didn't use anti-seize, but did use grease on the boots.You should not use anti-seize on NGK spark plugs because they feature a special trivalent plating on the threads, acting as a built-in lubricant and corrosion inhibitor, making anti-seize unnecessary and potentially harmful by causing over-tightening, leading to thread damage, shell stretch, or breakage. NGK plugs are designed to be installed dry to ensure correct torque and heat transfer, preventing serious engine issues like pre-ignition from altered heat ranges or stripped cylinder head threads.
100% agree. Anti-seize could also add electrical resistance since the plug is grounded to the head though the threads.You should not use anti-seize on NGK spark plugs because they feature a special trivalent plating on the threads, acting as a built-in lubricant and corrosion inhibitor, making anti-seize unnecessary and potentially harmful by causing over-tightening, leading to thread damage, shell stretch, or breakage. NGK plugs are designed to be installed dry to ensure correct torque and heat transfer, preventing serious engine issues like pre-ignition from altered heat ranges or stripped cylinder head threads.
It's impressive how lean even the turbocharged engine can run.. based on the brown/beige residue on the threads. You said you run your engine hard, right? I'd run those old plugs some more. We do 120k km intervals in the NA engine, and the ones that came out definitely looked a bit rougher than that.I used a 14mm spark plug socket and taped the extension to it. I would think the na has the same size plugs as the turbo but maybe not...super easy job..I used the OEM mazda spark plugs. 99.99999% sure they are rebranded ngk's...ok 100% sure but figured at every 40,000 miles it would not kill me to pay the price of oem....mine looked new so probably could have went double that....
The plugs should last 75,000, not 57,000. They probably last much longer than that as the tip is iridium and the ground is platinum.2019 NA model original plugs with 57000 miles. Any tips on changing? Is this standard 5/8 socket?
Thanks
yes...I went 156 in/lb which is 13ft/lbs. no anti-seize..Mazda's torque spec for the spark plugs is 15—20 N·m {1.6—2.0 kgf·m, 12—14 ft·lbf}.
That assumes no anti-seize or other lube on the threads.
yes I run it pretty hard usually in sportmode...I like having the revs up...If I had known how good they looked I would have not changed them but I already had the plugs and did the work so I did replace them but looking at them I could have easily ran them to 60,000 miles...gaps measured exactly the same as the new ones...It's impressive how lean even the turbocharged engine can run.. based on the brown/beige residue on the threads. You said you run your engine hard, right? I'd run those old plugs some more. We do 120k km intervals in the NA engine, and the ones that came out definitely looked a bit rougher than that.
I have the same socket. I like that it has the springs to grip the plug and no rubber insert to fall out.I used this socket
https://www.amazon.com (commissions earned)
Buy ATLIN Thin Wall Spark Plug Socket 12-Point, 14-millimeters Compatible with BMW, Nissan, Mini: Spark Plug & Ignition Tools - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
