SCBS Light after firmware update
2017 CX5 touring, A while back, I updated my software to the newest version, 74.00.324. Since then, I've had a SCBS and a parking brake fault light on. I've replaced the battery and the brake switch, and the lights are still on. If I scan codes, I get u0323 Software Incompatibility With Instrument Panel Control Module. Everything functions normally including the auto hold, but I cannot get the lights to go out. Anyone have this issue or something similar? About to just pop open the gauge cluster and tape over the lights as a last ditch.
I would send a private message to @Candurin. He might have a fix for you.
The only issue is that this is likely a PCM issue and not anything a CMU update would address. Additionally, they are already on the latest FW.
I did mention that in my DM response, it wanted to share here in case anyone else experiences the same.
Thanks for the replies, appreciate the DM Candurin, just wanted to post in the forum in case someone else had a similar problem. Ill try the steps in the post linked above and report back.
