2014~2018 Mazda3 OEM Big Brake Upgrade
2001 BJFP MT
2016 BMYFS AT
When we first got the 3rd gen 3, the rear brakes looked obviously like it was able to fit something larger from a different Mazda. The parts catalog showed that the brake shield is off a CX-5, so that was a clue. My hunch was right, but people on another popular Mazda3 forum discovered long before I did that the CX-5 brakes did indeed fit. They also discovered the 3rd gen 6 brakes also fits, but are slightly smaller/lighter than the CX-5's but nevertheless a small but significant upgrade over the 3's. They also discovered that the CX-9 front brakes also fits, and eventually the CX-5 turbo used similar brake calipers and same size rotors from the CX-9.
On a freeway panic stop over the summer, the "big" stock 2.5l brakes got cooked. Rotors got "warped" and no amount of hard stops afterwards could undo the uneven pad transfer on them. The lug nuts have always been torqued evenly by hand too. Seeing as the brake pads were down to less than 6mm left, I decided it's time to replace and upgrade the brakes to CX-5 ones.
Anyway, let's break this down in rotor sizes:
ModelFront Rotor Diameter & ThicknessRear Rotor Diameter & Thickness
3rd gen 3 1.5l/1.6l/US 2.0l Engine11.0" x 0.98" (280 x 25mm)10.4" x 0.35" (265 x 9.0mm)
3rd gen 3 2.5l Engine (2.0l Engine non-US/Canada, Diesel worldwide)11.6" x 0.98" (295 x 25mm)10.4" x 0.35" (265 x 9.0mm)
3rd gen 3 Hybrid11.7" x 1.1" (297 x 28mm)10.9" x 0.39" (278 x 10mm)
3rd gen 6Gasoline / 2013-2021 Diesel: 11.7" x 1.1" (297 x 28mm)
2022-2025 Diesel: 12.6" x 1.1" (320 x 28mm)
CX-511.7" x 1.1" (297 x 28mm)11.9" x 0.39" (303 x 10mm)
CX-5 Turbo12.6" x 1.1" (320 x 28mm)11.9" x 0.39" (303 x 10mm)
CX-912.6" x 1.1" (320 x 28mm)12.8" x 0.43" (325 x 11mm)
The brake calipers and pads are also obviously different. The biggest difference I discovered is that the 3 has "rust proof" and "heat resistant" phenolic front caliper pistons. Great in theory, until they get too hot.
The brake pads are a lot bigger in the CX-5:
ModelFront Pad Area & ThicknessRear Pad Area & Thickness
3rd gen 3 1.5l/1.6l/US 2.0l EngineJapan built: 8.293sq in x 0.39" (5350mm² x 10mm)
Mexico built: 7.750sq in x 0.39" (5000mm² x 10mm)
Japan built Cable Parking Brake: 4.108sq in x 0.35" (2650mm² x 9mm)
Mexico built Cable Parking brake: 4.340sq in x 0.35" (2800mm² x 9mm)
EPB: 4.737sq in x 0.35" (3056mm² x 9mm)
3rd gen 3 2.5l Engine (2.0l Engine non-US/Canada, Diesel worldwide)Japan built: 8.293sq in x 0.39" (5350mm² x 10mm)
3rd gen 3 Hybrid8.432sq in x 0.39" (5440mm² x 10mm)Cable Parking Brake: 4.51sq in x 0.31" (2810mm² x 8mm)
EPB: 4.991sq in x 0.35" (3220mm² x 9mm)
3rd gen 68.432sq in x 0.39" (5440mm² x 10mm)Cable Parking Brake: 4.51sq in x 0.31" (2810mm² x 8mm)
CX-59.300sq in x 0.39" (6000mm² x 10mm)Cable Parking Brake: 4.340sq in x 0.33" (2800 x 8.5mm)
EPB: 4.340sq in x 0.35" (2800mm² x 9mm)
CX-5 Turbo9.517sq in x 0.47" (6140mm² x 12mm)4.340sq in x 0.35" (2800mm² x 9mm)
2nd gen CX-99.517sq in x 0.47" (6140mm² x 12mm)5.689sq in x 0.4" (3670mm² x 9mm)
The caliper piston sizes are also bigger:
ModelFront Caliper Cylinder BoreRear Caliper Cylinder Bore
3rd gen 3 1.5l/1.6l/US 2.0l Engine2.1" (54mm)1.4" (36mm)
3rd gen 3 2.5l Engine (2.0l Engine non-US/Canada, Diesel worldwide)2.1" (54mm)1.4" (36mm)
3rd gen 3 Hybrid2.25" (57.2mm)1.5" (38mm)
3rd gen 62.25" (57.2mm)1.5" (38mm)
CX-52.37" (60.3mm)1.5" (38.2mm)
CX-5 TurboDual Pistons: 1.79" (45.4mm)1.5" (38.2mm)
2nd gen CX-9Dual Pistons: 1.79" (45.4mm)1.687" (42.85mm)
I decided to get the non-turbo CX-5 front calipers rather than the dual pistons turbo ones because they're cheaper, lighter weight, and better matching with the master cylinder size on the car since I'm not upgrading the master cylinder. The CX-5 turbo has a bigger master cylinder than the non-turbo ones. Getting the turbo calipers will get the "ultimate stopping power", but the much heavier unsprung weight will hurt handling a lot more than the small impact it already has with the larger/heavier than stock non-turbo CX-5 brakes. Fitment won't be an issue with the stock 18" wheels, however.
You might have noticed that the CX-5 (and even 6) front brakes are only 2mm larger than the stock 2.5l ones. But the true upgrade lies in bigger pads, steel pistons that won't distort/crack and seize compared to the stock plastic resin ones, and 3mm thicker rotors that have much better ventilation design. The gives much higher thermal capacity that makes it more reliable without a big impact on unsprung weight. I haven't heard of any stories about caliper piston issues yet on the 2 and 3, but on other brands of cars with phenolic caliper pistons, the plastic resin eventually distort or crack, causing major issues. That's not acceptable to me on a long term safety standpoint.
Not only that, the CX-9 rear brakes are not fully bolt on. Fabrication is needed for the calipers to fit with its bigger rotors. In addition, our car has a traditional cable parking brake, not EPB. This limits the rear upgrade options to either the early 3rd gen 6 or the early CX-5. On that other forum, most people upgraded to either 3rd gen 6 brakes, or later CX-5 ones with the EPB as the ones who do care and posted there have a later 3rd gen 3. You can however, use the CX-5 rear rotors with CX-9 rear calipers. That bolts on and will give full pad coverage of the rotor compared to any year CX-5 rear caliper. For any of the 3 possible EPB rear caliper upgrades, changing the EPB motor connector is needed as it's different than the stock one. You can cut and splice the connector, but it's a better idea to just get the rear brake wiring harness off a 2016 6 or CX-5. I think it runs into the trunk and plugs into the main body harness there. Not hard to do and I think it's a better idea because it's a high moisture and movement area. Any splices are a failure point.
Also to note: the stock calipers are made in China, whereas the ones on the 6 and CX-5 are made in Japan. Just another fact about cost cutting measures Mazda did to the 3 to keep the car affordable lol
The master cylinder bore sizes:
ModelMaster Cylinder Bore Diameter
3rd gen 3 1.5l/1.6l/US 2.0l Engine0.8126" (20.64mm)
3rd gen 3 2.5l Engine (2.0l Engine non-US/Canada, Diesel worldwide)0.8126" (20.64mm)
3rd gen 6Cable Parking Brake: 0.8126" (20.64mm)
EPB: 0.8748" (22.22mm)
CX-50.8126" (20.64mm)
CX-5 Turbo0.874" (22.2mm)
2nd gen CX-90.8748" (22.22mm)
100% brand new parts from Mazda is crazy expensive these days, so I opted for used ones from the junk yard. New/reman aftermarket ones don't all seem to have the Mazda logo/branding on them, so I'm a little picky about having them. So, I settled for used ones as that guarantees I get "genuine" parts.
They came functionally in good condition with half worn brake pads, but cosmetically, they were pretty bad. Surface rust all over, lots of grime. Typical junk yard junk lol
I ended up cleaning and painting them, which was a day's work:
Next, I had a hell of a time finding Advics high carbon 2019-2025 CX-5 rotors. These are certified high carbon, and the 2019-2025 rotors have vented hubs which the earlier years don't have. Must be a supply chain issue or something because they sold out quickly once they came back in stock for me to order them from Rock Auto. Other places were pretty much sold out during the summer. These are cheaper than OEM ones and probably a lot better too. They're also fully coated for rust protection.
Then, I had to get a "matching" unvented rear rotor too:
As for brake pads, I used to be a fan of OEM brake pads, but the stock brake pads on the 3rd gen 3 left a lot to be desired. Mediocre initial bite, mediocre pedal feel, lackluster high speed/high heat performance.
So, I was going to get Endless SSS brake pads as they're known to be low noise, low dust, and Endless pads (the racing versions) are used by official Mazda racing teams in Japan, so that seems pretty "kosher" to me. But reviewing the specs, they weren't that great compared to the Project Mu Type-PS which I already have on my Protege. But good timing has it, the Project Mu Type-PS HW (HW for heavy weight) just came out in June for very select vehicles. The CX-5 is one of them. So, that is what I got:
img_8817-webp.344195
img_8818-webp.344196
img_8816-webp.344197
img_8819-webp.344198
They're advertised to still have the same behavior as the regular Type-PS: decent initial bite, decent pedal feel, decent modulation control, very good high heat stopping power. As you can see in the pics, they're rated for 500 degrees celsius (932 degrees fahrenheit) with no warm up necessary. Although on my Protege, I've found that heating the pads up do make a huge difference in performance. The coefficient of friction is a very good 0.38mu cold and excellent 0.50mu hot. For a low noise, low dust street pad with these well rounded characteristics that's unoffensive like stock, it's pretty rare.
It was a good thing I got them before the tariffs hit. For the price of 2 sets of OEM pads from the dealer (with discount), I got these Project Mus to my door straight from Japan. No stupid performance shop markups here.
I bought new OEM shim kits from eBay for much less than what the dealer would charge, and scavenged the wear squealer clips from the used CX-5 pads. The rear pads have squealers on both sides and they sit towards the ground once installed on the car. The front one goes in the inner pad towards the top of the car.
For the first time ever, I used the OEM slider pin and pad guide grease I bought from Japan. I didn't buy the OEM grease for the shims and used the Wurth one from my old job which works good.
The shim kits also came with a pack of copper "Molykote" 7439 antiseize that goes on the mounting tabs of the brake pads. All of the prep work/assembly took much longer than expected, but everything is assembled almost like factory condition.
Special attention also must be paid attention to the front guide plates. I didn't pay attention that the top and bottom ones are different when taking the used ones off to paint the calipers. The shop manual is confusing, but after reviewing other people's pics/how-to guides, the guide that doesn't sit flush with the caliper bracket goes to the top end of the caliper, while the one that clips all the way flush sits in the bottom side.
And then stupid me for not noticing that Mazda changed the rear caliper bracket bolt size from M10x1.25 bolts to M12x1.25 bolts in 2015. So, this meant I had to drill out the smaller caliper mounting holes in the rear spindles to fit the bigger bolts. This was a nightmare on a late weekend night with worn drill bits, after having to run across town to find the proper M12x1.25x35mm flange head bolts at a hardware store, but perseverance paid off in the end. For no fuss 100% bolt on, get 2013-2014 CX-5 rear calipers if you have a early 3rd gen. Otherwise, you're still stuck having to drill the holes on a later 3rd gen, and also needing to change out the EPB motor connector to the CX-5's or 6's
The other nightmare is taking the parking brake cable off. It seems there's no way to unclip it from the caliper without loosening the cable adjustment at the hand brake lever. The Protege is so easy to take off the cable by comparison.
So finally, the "before" and "after" pics:
Finally, I flushed out the Castrol GTLMA DOT4 brake fluid with Endless FP-6 DOT5.1 Class 6 low viscosity, then went for a test drive. Of course new brakes always works great, but the biggest difference I now feel is that the brake bias is a lot more balanced. The car doesn't nose dive as much under any braking anymore, which makes it more similar to the Protege. The nose diving, which is pretty normal on most cars, bothered me a lot when we first got this 3rd gen 3 as it was very un-Mazda like. So, now it's fixed.
Also, this upgrade might fit other "cheap" Mazdas such as the CX-3 and CX-30 due to a lot of parts sharing between models these days. But, I don't know if they bolt up or not. When I have time, I'll go measure the bolt spacing on the stock calipers and post them here for reference.
As for those of you who think the stock brakes are fine and you can get better pads for it, the selection is pretty bad for the stock calipers. Race teams actually upgrade/swap the brake calipers to one of the better ones listed for better track reliability and better performance brake pad availability. Stock "works fine" for just driving around town, but they're marginal with highway driving, especially when your car is packed with passengers and luggage. Sure, the stock brakes are better than most cars, but then again most cars have crappy brakes anyway because good brakes aren't a priority in America compared to Europe.
So, if you're on a budget and have a lower end 3 with the smaller brakes, at least upgrade the front brakes to the bigger ones. It's just a simple bracket and rotor swap. Calipers and pads are the same.
If you have more money, then do the full brake swap like I did lol
While I haven't had to perform any emergency maneuvers, I did do a "test" after I put my Akebono ProACT ceramics on, since everyone says they have less bite than the normal pad material. At 65 mph with 3 passengers, I momentarily hit the brake pedal pretty hard to check the response. After the jolt, let's just say that everyone was certain that if we really needed to stop, we would be stopping. :D
The Akebono pads are very well regarded aftermarket stock replacement pads. Even a Kiwi friend down under swears by them and went out of his way to import them for his MSP brakes setup. But I decided to get something better given the opportunity and to review at the same time what's still not available here yet (I don't think any of the Project Mu pads are technically legal here as they don't have DOT pad codes)
But, 65mph is nothing. Try a panic stop from 85+ MPH to 30 MPH to avoid a major obstacle on the freeway with a fully loaded trunk on 100% stock brakes. Does the job, but the brakes gets cooked. Still works afterwards, but rotors "warped".
There's a reason why European cars usually have big brakes, here and across the pond in their "domestic" market: Speed limits in most European countries are usually 75MPH, but just like anywhere in the world, speed limits are regarded as "suggestions" and people drive much much faster than 75MPH when their car has enough power to do so. 90MPH isn't uncommon, and 110-120MPH isn't either even in a country that's not Germany as I've seen myself on a recent European trip. Yes, I drove the rental car at 110MPH for at least 20 miles when the limit was 75MPH. I still got passed by a car or two. Gas mileage went to hell, so eventually I backed off to 95MPH when the road got hilly and twisty lol... Anyway, those big brakes are really needed to avoid brake fade from a high speed stop. Any brakes will stop a car these days, but what condition they are in afterwards is the big key question. Big brakes shouldn't have a problem, but smaller brakes will get cooked
So, when safety is important, don't skimp on brakes
But since you have a turbo CX-5, I'm sure your brakes are quite adequate compared to the pitiful ones the 3 has. Just do swap out the stock DOT3 brake fluid with good DOT5.1 like I did. Endless is well regarded and amongst the best. Price per ounce comes out a little cheaper than the Castrol SRF DOT4 and it works better than the Castrol too. Both of them are not as hygroscopic as the traditional popular performance brake fluids such as Motul and ATE. I used to use Motul 600 in my Protege but I didn't learn till 2 years ago that it's super hygroscopic and much better fluids have came out since it first debuted back in the 90s. So, I've moved on to using Endless (different kinds) for both my Mazdas, and sticking to (JDM because much cheaper and I buy them while on vacation) Castrol for the Toyotas as both brands are low moisture absorption. You can't go wrong with other JDM brake fluids such as Wakos too, but given the money already spent, I'd just go for the best and known lol
I may well have been going 75 mph, but regardless, it was only a quick test. I didn't want to go hard on the rotors for no reason. Highest I've had this car was 85 mph and it was super smooth and controlled there, more so than any car I've owned save for the 2000 era Pontiac Grand Prixs with the 3800 V6. Those cars were tight as well. My Corksport springs and the performance wheel and tire setup are surely helping the car feel so planted, because I know in stock form there was a front/rear wobble when making steering adjustments at speed that I did not like. That tightened up with the higher rear spring rates and 245/45 tires on 9" wide wheels.
I'm still on stock suspension with Autoexe strut bars and tie bars. Not going to do more than except maybe sway bars. The strut bar makes steering response too good, so if you're not careful, you can make the car really twitchy. The i-DM monitor (I turned it on by hack) reflects this lol
Handling is OK for stock, just neutral understeer if you drive it right, but the only thing that really bothers me is the body roll, which obviously stiffer springs will fix but I won't do because of ride comfort and convenience (the stock ride height is great for driving over obstacles and bad roads lol). I bet sway bars will fix it and eventually once the stock struts/shocks wear out, I'll upgrade to Konis. Not a big fan of the Chinese made stock Tokicos (one rear shock already leaky since around 40k) lol
I've taken a different path and decided to stick with OEM sway bars. I'm of the belief that if you address the springs and shocks, you will have a better overall result with greater independence between each side of the car. Stiff sway bars tie the left and right sides of the car together such that imperfections on one side will be sent to the other side of the vehicle. Food for thought.
You can get sway bars that are way too big or get something in between that makes it more suitable for stock springs/shocks. At least the USDM 3 has a bigger rear sway bar off the 1st gen CX-5 compared to the rest of the world. It's the same size as the Autoexe one meant for the JDM 3. So, those with USDM 3s need to get the one meant for the CX-5 if they want Autoexe lol
I haven't decided to do anything else with the suspension yet. It's going to be a while since the stupid tariffs took hold
As for how the front CX-5 pad guides fits, here's a pic of them in a front right caliper:
You will see that the "trailing side" is facing towards the ground:
The "leading side" guides do not sit all the way flush into the caliper bracket when no pads are installed. You can barely see that in the pic above.
For both guides, Mazda recommends applying the Molykote 7439 copper anti-seize between the bracket and the guides and between the guides and the pads.
As for the squealer, as mentioned, it goes on the "upper" ("leading" in Mazda speak) side of the inner pad:
The rear pad guides are all the same, so no special attention is needed where they need to go. Mazda still recommends applying Molykote 7439 copper anti-seize in the same places as the front calipers.
The wear squealers will still go on the "leading" side of the pads, which in this case are where the pads are pointed towards the ground, since the rear calipers sit towards the back of the car instead of towards the front, unlike the front calipers. There are wear squealers on the inner and outer pads.
Interesting development, I was planing to upgrade the front brakes with a set of rx7 4 pot caliper and the 295x25mm rotors.
Have the rx7 form a trade few years back and as I noticed the front brakes need an upgrade what better than rx7. Surprisingly the mounting location of the rx7 caliper is few mm shorter. The rotor offset on Mazda 3 isn’t as big to match that easy so a bracket is required to make it work, which I have plans to do but not in hurry at the moment.
The good thing is that it will match well with stock rear brakes(not EPB).
Happy you shared the specs and made the change 👍
First thing I upgraded on 16’Mazda 3 was the springs on stock shocks & struts, got the racing beat and it made the car much better and enjoyable but not harsher.
I’d recommend these springs to anyone if you want a great daily oem plus upgrade.
Next upgrade will be bilstein B4 front and rear with new top mounts
You will see that the "trailing side" is facing towards the ground:View attachment 345086
By the way, have you modified the rear motor mount yet?
I get a whistle sound from around atx since I changed the trans mount to an aftermarket oem like replacement, although it raised the trans side about 3/8in guessing, the stock was worn out and squashed down some.
Next in line is the rear mm, have you found any better solution than cs rmm ?
Can you describe the sound more? It's not an RPM-dependent whine is it?
So far it is noticeable around 15 to 25mph, over that it’s hard to notice it.
The whine sounds like that of a super charger but much lower volume and kind of muffled tone.
wow thanks for your info! It is the best report/testing so far!
By the way, I am with base trim of 2024 Cx5 in Canada - GX...I do feel the OEM(came with the car) is too soft to stop(initial bite as well as stopping power) so I replaced with Raybestro ETH front and rear pads from RockAuto right away - front pad rated as GG and rear pad rated as GH.
It is day and night for stopping power.
I do notice Turbo CX 5 comes with bigger rotor/pads with DUAL PISTON caliper....
My question:
Does Turbo version of Front Caliper fit on non-turbo car?
NOTE - turbo wheel is 19 inch where non-turbo is 17 inch wheel.......
It should, but I don't know if they also need the master cylinder or any other parts changed to go with them.
I do feel the OEM(came with the car) is too soft to stop(initial bite as well as stopping power) so I replaced with Raybestro ETH front and rear pads from RockAuto right away - front pad rated as GG and rear pad rated as GH. It is day and night for stopping power.
People use this term a lot, but it's really about brake pedal feel, because the car will stop in the same distance with the stock pads if you really need to stop. The ABS system will kick in to prevent wheel lock in both cases.
My question:
It does, but it's better to upgrade the master cylinder to the turbo one... might be a tight fit or no fit with the 17" wheels though... I know it's already a tight fit with 6 or CX-5 non-turbo brakes with 16" stock 3 wheels
You can also upgrade the rear caliper to the 2nd gen CX-9 ones for full coverage of the rotors... most people rant and rave about Akebono pads which are said to be way better than stock, and they're an OEM supplier to Mazda, Toyota, etc. So I think their quality is better than Raybestos
I don't think so. While the Project Mu pads and CX-5 brakes combo in my car feels similar to the GR Corolla's brakes, I have no empirical data to claim whether one is good as the other. However, these brakes now indeed make the car stop way harder and faster than the stock ones ever did. The better brake balance means the likelihood of the front brakes locking up is less due to lesser weight transfer. I've done very hard and short stops from 75+MPH many times already and never has the ABS kicked in, but the car knew it was stopping hard and kicked in the automatic gear downshift more sooner than it did before. I've done hard stops at 75+MPH on the stock brakes and never had the ABS kicked in but the distances were much further. It takes a lot to get the wheels to lock up with decent tires on these cars
Initial bite on the Project Mus are good, as advertised. It takes no time heating up, and they continue to bite very hard the more you stand on the brakes. Even feather light pedal touch on cold brakes stops better than stock did, because of the much more aggressive compound. There's some brake dust in the 500 miles of brake use but it's quite similar to stock. No noticeable dust build up on the brake parts during a recent tire rotation
