What have you done to your CX-9 today?
You don’t think the steering wheel is off-center?
Might be a very little bit. Hard to tell from this angle, for certain.
As for slight tendency to pull to the left or right, my CX-5 also has that ... a little. And my previous Mazda3 had that. Wasn't ever enough tugging, for me to bother getting changed. You'll need to judge whether it's enough for you to press the issue, or to head to a high-competency specialty alignment shop that has top-notch techs.
Once had a Mazda Miata and found a tech in my town at a great shop that had good-quality Hunter RoadForce equipment, and he was willing to "nail" the alignment every time. Was worth every nickel, to get that guy and his experience every time.
One thing I noticed on your alignment specs: the front camber differs quite a bit, L vs R sides. Shouldn't make any difference on tugging to the left or right, but it will have some impact on cornering ability when cornering one direction vs the other. Something to note on your next alignment.
Yeah, I noticed that too regarding camber and actually brought it up with the technician who worked on my car. He said they’re not able to change the camber on the CX-9. I don’t know much about cars, but I’m not sure how true that is.
It is possible to change the camber justva pain in the ass. With the what looks like a very slight pull to the right thats been on every vehicle I have driven. Even had an old timer coworker tell me it was a safety feature.(not sure how true that is)
Find a safe area flat and open. that you can get up to 50km or 30miles with your hands off the wheel and in a straight line brake hard and see if it pulls hard to the left or the right. If the car feels like it moved on its own. If it feels like it moved more then a foot either direction I would personally have a concern 4inches or less I wouldnt bother looking into it further.
With my 2019 I did this test running my driver's tyre along the line in the road and assuming it was straight I only move off it about an inch in 500ft idling
A little over 2 inches after I brake hard.
It's true. Camber is not adjustable on Mazdas. You need aftermarket adjustable control arms in the back and camber bolts in the front, or adjustable coilovers that have camber.
I've always been told that the front camber can be adjusted, but only very slightly. The rear can't be adjusted. I've also tried to look for adjustable rear camber arms, but only found one instance of one guy in Japan who had adjustable rear arms installed, but he had to notch his subframe to get them to fit.
All depends on how redneck you want to get.
What's needed to adjust camber on the rear? Say I wanted to add some positive camber to bring it from -1.5* to -0.5*?
I remember you were looking at the measurements of CX-5 arms. Were they different?
Oh right, thanks again for measuring your CX-5 arms. I did mean to measure my own but forgot to do it.
I took a couple of minutes to scurry around under my car just now. It's tough to get an accurate measurement, but I think the CX-9 camber arms are just a bit bigger. Something like 0.5" to 0.75" more from hole to hole. It's close enough for me to try to measure it again with the wheel off, so I'll probably do that during my wheel swap in the spring.
I will send a DM as this is a use at your own risk deal, dont want people saying agape said...
So update on the off-center steering issue. To recap, I had my front lower control arms and sway bar end links replaced with OEM Mazda parts that were verified with my VIN. I got my vehicle back yesterday and the technician said they’re unable to recreate the issue. Went on a road test with them and the issue is still there but they basically turned a blind eye and said, “nah, that’s normal.” I’ve attached videos of my concern, as well as the alignment sheet the Mazda technician gave me.
Lmk if I’m going crazy or if you guys see the problem too 😂😂
Hard to tell based on the videos... But often these things are felt and hard to see or recreate.
Good suggestions from experienced users you may want to consider.
It might ever so slightly to the right. However, you don't think that is because all roads are slightly banked to the right to allow for water to runoff to the sewer?
Nah, definitely not. Before I had the front lower control arms and sway bar links replaced, the steering wheel would be centered regardless of the lane I was in, or the road.
I’ve attached two photos and a video showing the front driver side tire and how it’s slightly turned to the left, even though my steering wheel is completely centered.
  • IMG_4931.mov
    26.7 MB
Did an oil change yesterday using Kirkland 5W-30 and a Mazda OEM filter. There's only like 2k kms on this oil, but I felt that I should change it anyway because I bought it from a used car dealership. Turns out I was right to change it..
1000044806-webp.344936
Thats a Certified CPH6607 universal oil filter from Canadian Tire. Certified is CT's "value" line. The shop even over torqued the drain plug because they used the wrong size crush washer and I could see how much it had been compressed. Anyway, happy to avoid any risk and change it now instead of running it all winter.
Also updated my infotainment firmware to 11048 thanks to @Candurin 🙏
1000044679-webp.344937
Installed some 5mm spacers in the rear today.
attachment.php
Before:
attachment.php
After:
attachment.php
The difference is minimal, but I can see and appreciate the difference. The front and rear stance now matches properly. Not bad for $5 spacers haha.
I also need your help guys. I got these bigger mudflaps because with the wider tires, rocks are more likely to kick up and hit the sides of my car and other cars behind me. The car also gets much dirtier after driving on wet roads. Now that I've mocked them up, I don't know how I should install them. I have mocked them up with some tape, shown below (they would be installed a little higher and flush to the wheels). Should I mount them with the existing mudflaps (like in the photo), mount them without the OEM mudflaps, or leave it as is (no aftermarket mudflaps)? Personal opinions are welcomed.
attachment.php
What size RallyArmor Universals did you end up going with here?
I didn't end up installing them on that car, but I still have them, and will probably install them on my current car (2022 CX-9). I think they are the basic mudflap, which is about 12x15 inches.
Nice!
Any difference with the infotainment?
I'm pretty sure mine is still from 2018 🫢
Nice!
None that I can tell on the 2022. On the 2018 though, I had version 56.xxx.xxx I think, and then updated to the most recent version. That made the infotainment feel a bit snappier.
Have you tried the Pennzoil ultra platinum? Pretty good reviews, very popular from that project farm yt channel on testing etc. I've had really good results using if so far. They had a really good sale a few months back at CT... With the MIR, it was $28.99 for the 5L jug. (Max 10L purchase)
Yeah that is a very good sale on it.. I did use PUP for the first few oil changes with my 2018. Since then I've been using the Kirkland stuff and I find it to be a good oil for my needs. I stocked up a few years ago when it went on sale, $40 for 2 jugs, and I'm finally going to run out next year lol.
