Guide Mazda2 DE Instrument Cluster replacement
You'll need:
An instrument cluster
Windows laptop
FORScan with the extended license (You can get it for free for two months) - FORScan Home
At least two PATS Key (If you don't have two keys or you don't program at least two keys during the step 6.5. you will brick your car until you get two keys programmed)
OBDII adapter (I used an OBDLink EX - it must be ELM327 compatible)
1. Disconnect the negative battery cable.
2. Lower the steering wheel.
3. Remove the meter hood. Pull the meter hood in the direction of the arrow shown in the figure and remove it while detaching the clips.
4. Remove in the order indicated in the image.
5. Install in the reverse order of removal.
6. Program the immobilizer system-related parts when replacing the instrument cluster.
6.1. Connect OBDII adapter;
6.2. Put the ignition to ON position;
6.3. Launch FORScan and connect to OBDII adapter;
6.4. Go to Service Functions and select IC PATS Programming;
6.5. Choose Ignition Key Programming and follow the instructions;
6.6. When both at least two keys are successfully programmed, exit the procedure;
6.7. Again, in IC PATS Programming, select Module Initialization and follow the instructions;
6.8. Once complete, cycle the ignition OFF and ON;
7. Test if the car turns on.
If you have any questions do no hesitate to ask!
In my 2012 DE I have the most basic cluster it displays milage and fuel that's all. I would like the cluster that also displays fuel milage and so forth but don't know if that's possible..?
Yes it’s possible! I’ve actually tried to do this few weeks ago and have made a detailed guide to do it: Guide - Mazda2 DE Instrument Cluster Swap | Comprehensive Guide
Let me know if you’re trying this or have any questions ill try my best to help 🙏
