DIY Mazda Firmware Update Information
Thank you for your help.
Firmware update completed successfully. Followed the instructions and had the desired results. Updated from 59au to 74 Au. No problems.
Hello,
I'm looking for the latest software update for my 2018 Mazda CX-3, I'm currently on 50. something and would love to be able to update for apple CarPlay. I believe i need the NA software as I'm in Canada.
PLEASE READ THE POST IN ITS ENTIRETY BEFORE POSTING A REPLY IN THIS THREAD.
IMPORTANT NOTE: These files and processes are compiled from third party sources. Please be aware of the risks of performing these updates yourself. There is potential to brick your CMU if some steps are missed or the wrong files are used. Mazdas247 does not assume responsibility of the actions taken by its members or the damages that may result from those actions.
These files are being provided as a courtesy to our members, to allow them to avoid the potential dealer fees and time wasted in the dealership, waiting for a technician to perform these updates. A previous member of the Community was kind enough to provide these source files and instructions - as such, these files and the links that may be provided to you carry no guarantee that they will remain intact in the future.
Typically, most people will perform these firmware updates in conjunction with an Android Auto Apply CarPlay retrofit kit, which can be purchased or ordered from any Mazda dealer. However, these firmware updates may also resolve certain bugs and glitches in previous versions, and may also improve overall performance of the infotainment system.
The most recent, and final update at this time is 74.00.324A. This firmware version/format (.up) will not be installed on new Mazdas. You must use the correct region for your Mazda, as detailed below.
74.00.324A NA N for North America, USA, Canada, Mexico, etc.
74.00.324A EU N for Europe and UK, etc.
74.00.324A 4A N (ADR) for Australia, NZ, Middle East, Thailand, South Africa, Oceania, etc.
APPLICABLE MODEL(S):
2014-2018 Mazda3
2016-2021 Mazda2
2016-2021 Mazda6
2016-2021 CX-3
2016-2021 CX-5
2016-2021 CX-9
2016-2021 MX-5
***UPDATE as of Oct. 2nd, 2024***
The following versions are also available for the '21-'24 models listed below.
7000C0A-NA11_10010 (2024 CX-90)
7000C0A-NA05_11022 (2023 CX-50)
7000C0A-NA10_10004 (2023 MX-30)
7000C0A-NA02_11046 (2022 MX-30)
7230C1A-NA03_10022 (2024 CX-30/Mazda3 w/ NAV - USA)
7230C5B-NA03_10022 (2024 CX-30/Mazda3 w/ out NAV - USA)
7230C2A-NA03_10022 (2024 CX-30/Mazda3 w/ NAV - Mexico)
7230C6B-NA03_10022 (2024 CX-30/Mazda3 w/ NAV - Mexico)
7000C0A-NA06_12018 (2021-2023 CX-30/Mazda3)
7000C0A-NA12_10016 (2024 CX-5)
7000C0A-NA03_11048 (2021-2023 CX-5/CX-9)
7000C0A-NA01_12006 (2021-2023 CX-30/Mazda3 Non-Turbo)
7000C0A-NA04_12006 (2021-2023 CX-30/Mazda3 w/ Turbo)
To gain access to these files, please PM @Candurin.
Do not post in this thread asking for the links or files. your post may be missed. Keeping track of PMs is much easier.
Note that firmware versions are region specific, so when you send a PM to @Candurin for the links, be sure to specify the following:
1. Your car model
2. Your current firmware version installed (format should be XX.XX.XXX or 7XXXXXX-NAXX_1XXXX or something similar)
3. Your region
Could you please help me to find latest update for Mazda Axela Australia & new Zealand?
Please read the post in its entirety and follow the detailed instructions.
To gain access to these files, please PM @Candurin. Do not post in this thread asking for the links or files. your post may be missed. Keeping track of PMs is much easier.
I just successfully completed firmware update for 2019 Mazda CX-5 as described in this thread. I started the process in an attempt to get back Android Auto in addition to other benefits I learned about. (I checked USB cables, etc. first)
Before and after the update, DTC B108E04 Display System Internal Failure shows on test screen. From what I see in code forums, it is likely due to one of the following reasons: Faulty Front Display Interface Module (FDIM), FDIM harness is open or shorted, FDIM Module circuit poor electrical connection, or faulty Accessory Protocol Interface Module (APIM).
Does anyone have other suggestions for the CX-5 display code? If connections are not the issue, any pointers on which OEM fix I should look into? Can the FDIM or APIM be replaced separately or better time trade off to get a larger component that includes the FDIM and APIM? Thanks,
Rald
12/16/24 Update: android auto is now working after firmware update (I noticed some apps were needing updates (like Android Intelligence) and also questioned if I properly unpaired phone as had been instructed. I tried pairing phone again with Android Auto and now it works so for now I believe that I can ignore the above DTC that I had cleared, but continues to pop-back up. In hindsight, the code error part of post would have been better under a different category.
Sent the PM. Looking forward to updating my wife's car. Hoping it fixes some quirky bugs she's been having.
I saw the video instructions and curious why people are using Parallels on Mac to do this?
Macs are capable of formatting the USB drive to Fat32 and pasting the update on to it. TIA
Formatting to Fat32 on the Mac did not work for me. No update file found error. Took the usb stick to an older windows 10 laptop, noticed there was a second update file beginning with a ".". Did not see this on the Mac. Hidden backup/temp file maybe? I'm new to MAC, so I may have messed something up too.
Anyway, format with Windows 10 worked. Note, this is for a 2019 CX5 GTR.
Also thanks to @Candurin for the file!
Thanks to @Candurin, updated my 2016 CX5 from 70.00.352_NA to 74.00.324_NA. The install went smoothly, it seems to stall for many minutes at 2%, 78%, 96% and 99% but takes 35 ~ 40 mins overall
Hopefully this should fix the issues I am having with iOS 18 - will test more tomorrow and report back
