CX-7 Transmission fluid change…Should I?
Status
Not open for further replies.
I have a 2010 Mazda CX 7 2.3 L. Presently I dont have any issue with my car. Doing change oil every 5,000 km. It has been great. However, it's mileage now is 160,000 km and Im not sure if I need to change the transmission oil. I recently checked the fluid level and it's still in a good amount of fluid. Im just trying to be pro active. Do I have to change the fluid even I dint have any issue in my transmission?
I also have drain/filled my transmission several times over the 155k miles my car has. Last time I mixed in some Valvoline MaxLife with the Mobil JWS3309 fluid. It has worked well in my '09 Pilot and fits the spec for the Mazda so I decided to try it. Transmission has always shifted great, the same now as when it was brand new.
Upvote 0
I just purchased a 2012 CX-7 2.3L turbo and wondering the same thing. It is not mentioned in the maintenance schedule or the owner's manual. Mine is a little low and one quart of the JWS3309 is $20. Was considering changing it but it's pricey.
Upvote 0
NOT using Mazda ATF is a false economy. Sure, $18 for a quart of Mazda ATF x 4 plus the filter is $100. Not cheap. But you know what's SUPER not cheap? A $3,000 transmission.
Just use the stuff that your owner's manual tells you to use. Besides, you're only changing it every 30,000 miles, far less often than motor oil.
Upvote 0
This fear mongering is simply unnecessary. You will not destroy your entire transmission from using non Mazda ATF.
Upvote 0
It isn't to save money, VML is a good fluid, full synthetic, has benefits that the oem may not have.
Upvote 0
I ordered the Mobil ATF™ 3309. The product data sheet says, "Applications: Mobil ATF 3309 is recommended for use in transmissions requiring fluids of JWS 3309 or GM 9986195 quality levels." I asked my mechanic and he says if it's equivalent it's fine to use. Sorry for hijacking your thread OP.
Upvote 0
Yes if it meets the spec you're good.
I have used the mobil fluid and valvoline maxlife in my Mazda (and VML for longer in my Pilot) and they're good.
Upvote 0
Trans fluid is trans fluid.
I've read some really bad takes but this has got to be the worst. Wow. If that's true, just throw some $3 Type F in there and call it a day.
Oh wait, this whole TSB thing that Mazda put out that specifically says to not use multi-grade ATF, and to only use type M5. Just ignore that, amirite? Because obviously a keyboard warrior on the Internet is far, far smarter than the Engineers who designed our transmissions.
Upvote 0
Being confrontational is no better (and will get you banned), please keep it friendly and informative. No need to be so sarcastic.
Thread Closed.
Upvote 0
Status
