Can I use CX-9 winter wheels on a CX-90?
CX-9 GT 2019
Hey,
Considering upgrading my CX-9 to CX-90. I have a good winter wheels with 255/55/19 winter tires on them. Can I keep them for CX-90?
Numbers look acceptable, did Mazda change offset or smth?
Looks like CX-90 stock 21" offset is also ET45:
18x8" et45 20.97 lbs/9.51 kg
19x8.5" et45 23.17 lbs/10.51 kg
21x9.5" et45 27.98 lbs/12.69 kg
Comparison with my winters looks acceptable, but might be a bit narrow.
I think it's doable. Backspacing could be a concern but I don't think the 90's brakes are big enough to cause fitment issues.
So long as it clears the calipers like someone else mentioned, i think it would be a good choice for your winter set.
going narrower is a good thing for snow traction.
ideally you would want a a 60 aspect ratio if running 255/XXr19, to bring the rolling diameter close to stock, but you're correct in pointing out that the difference is still going to be within range.
I know this has been a common belief but it has been tested and shown to not be the case. Don't worry about seeking out narrow wheels and tires for the winter.
Yea i've heard this a lot but I'm not sure if it is true.
I am wondering is my 205 width winter tires will be wide enough for my tuned FWD 6. Stock is 225. I wouldn't mind going up to 235 for my summer set due to the tune.
I’d think a 225/40R19 would be perfect for a summer option.
225/45R19, not 40 aspect ratio.
Not for me! The roads here are bad enough, that I refuse to drive on anything less than a 50 aspect ratio. I think my current 55 aspect ratio tire offers a great balance between compliance, grip and cornering response.
Don't want heavy 19's either.
Sorry- typo. I meant 245/40R19. Exact same sidewall height as your stock tires.
But if you want something taller, a 245/50R17 would be it.
Did anybody end up using this 255/55/19 tire on a new CX-90 or CX-70?
I have a set of 255-55-19 studless snow tires with only two seasons on them from my BMW X5, the car that I'm thinking of replacing with a new 90 or 70. With the ungodly cost of tires of this size I would love to be able to find a set of 19 inch wheels and reuse them.
