CX-5 Noise from Engine Bay when turned Off (with Video) - Any ideas?
Hello,
After turning off the engine of my 2022 CX-5, I always heard the fan run for a bit before it shut down. That seemed normal. However recently the a odd noise developed and not sure what this is? It is coming from the front of the engine bay- passenger side. The noise stops when the fan stops. Any ideas?
FYI- I can barely hear the noise when the car is running, so it is present at that time too.
Thanks!
Fan bearing? Or something trapped in your fan?
When the car is cold, start it up and switch on/off your A/C (which will also switch on/off the fan), then you can check if the fan itself causes the noise.
I did some more evals. It is not coming from the fan or the fan motor. The sound seems to come from the general area of this piece. I can feel the vibration on the passenger side headlight. Thoughts?
