Firmware NA03_11048 For 10.25 Inch Widescreen Update CX-5
  • Thread starter Thread starter 34403
  • Start date Start date
Status
Not open for further replies.
New Mazda Connect Firmware update for CX-5 and CX-9 with 10.3 Inch screen for North American market ONLY.
No Changelog has been issued.
CMU_7000C0A-NA03_11048.kwi * CX-5 + CX-9 2021 on with 10.3 inch center display.
MUST Private Message for link.
Hi, can you pm me the new software? Thanks
Changelog for NA03_ 11048
Some vehicles may experience the symptoms mentioned below,
which can be fixed with the latest software update (Version 7000C0A-NA03_11048 or later).
(Ver. 7000C0A-NA03_11048) fixes these software errors (bugs):
• The screen does not show a proper picture when receiving SiriusXM data.
(Ver. 7000C0A-NA03_11046) fixes these software errors (bugs):
• The vehicle icon rotates when using the navigation with head-up mode.
• The system reboots when operating the audio source screen.
• If another incoming call comes in immediately after the hands-free call is ended, it is automatically accepted.
• Audio tracks stop playing or are muted when playing them using the Apple CarPlayTM.
• The system may reboot.
• A beep sounds after every couple of minutes.
• Language setting may not be accepted correctly.
• The screen shows “Phone in use” message and it stops playing audio tracks while playing audio tracks
using CarPlayTM and refusing the incoming call.
• The audio track may not pause when pressing the mute button.
• The screen freezes when smartphone receives messages under Bluetooth® connection.
• The system does not resume a play list after editing it for an USB audio device.
Ver. 7000C0A-NA03_11040 fixes these software errors (bugs):
Ver. 7000C0A-NA03_1138 fixes these software errors (bugs):
• DTC U3000:49 is stored which may be accompanied with following symptoms.
- No sound comes out from the speakers.
- Audio source selection is unavailable.
- The system reboots.
Ver. 7000C0A-NA03_11032 fixes these software errors (bugs):
• Update detail screen shows incomplete sentence and trying to scroll to the
beginning of the sentence leads to the whole sentence disappearing.
• Turning the main power off may lead to a reboot while playing audio tracks
using Android AutoTM and displaying the map using Android AutoTM.
• Voice command may not be recognized.
• Turning the main power on may lead to a reboot after connecting a device to use Apple CarPlayTM.
• Android AutoTM may fail to connect.
• The 360° view monitor screen may be overlaid with the home screen.
• DTC for disconnection of the mic may be stored in the CMU after updating the
emergency call unit (TCU in MDARS) software.
• If the volume knob is pressed and held to turn the power off while adjusting Fader/Balance,
the lines showing current setting for Fader/Balance may not appear the next time the power is turned on.
• Turning the main power off may cause the display to keep turning on while using Android AutoTM.
• The parking sensor screen may freeze after particular operations.
• Track selection using voice command may result in the error message “Too many tracks.
This function is not available”.
• After selecting certain speed for the speed alarm, re-opening the screen shows default setting
instead of the selected one while multiple USB devices are connected.
• The device name may not appear when connected using CarPlayTM.
• DTC U2301:56 may be stored after installing an accessory device.
• Album artwork may not appear when playing music using a USB connected iPhone.
• Android AutoTM may not appear on the entertainment screen.
• The screen may turn black when using CarPlayTM.
• The screen may freeze when a Bluetooth® device is disconnected.
• The destination may not be registered when a destination is sent via MyMazda application.
• When it reboots, registered information for a paired Bluetooth® device may be lost.
• The center display may turn black when the gear is shifted from reverse position to park position.
• Steering switch operation for auto-tuning may erase the banner when listening to the radio.
• Screen freezes and goes to white screen, then the system reboots.
• The audio selection switch does not work.
• It takes time to establish Bluetooth® connection.
• Mobile911 function may not place a call while no Bluetooth® device is connected.
• Mobile911 function may not place a call when using CarPlayTM.
Ver. 7000C0A-NA03_11026 fixes these software errors (bugs):
• The system may reboot repeatedly right after starting the vehicle, and removing the navigation
SD card stops the rebooting.
Ver. 7000C0A-NA03_11024 fixes these software errors (bugs):
• Place markers setting may not keep the change and it may return to the default setting.
Customers having this concern should have their vehicle repaired using the following repair procedure.
Thank You ASH8 !
New to us 2022 CX-5 CE
CMU upgraded from 11038 to 11048 - approx. 15mins
TCU upgraded from 10020 to 10024 - approx. 15mins
The upgrade process went as documented.
Wife wanted me to take into dealer to get it updated, afraid something would go wrong. After she called dealer and hearing, "need to make appointment", possible 1-2hr wait time even with appointment or take it in during the week and wait for faster turn around. So, finally it was a no brainer to her let me do it.
I understand that performing this type of upgrade if not performed properly could have adverse consequences. I guess Mazda still needs to work on the OTA upgrade process to pickup on new available updates so clients do not have to bring vehicle in to do something that should be user friendly.
Two things I hope future update(s) would address at some point for the CX-5 (2020+) below Premium trim is the ability to see tire pressure for individual tires on vehicle display or at least on the Mazda app since majority have TPM sensors.
The other being the ability to display digital speedometer on all display types.
I know, I shouldn't hold my breath.
Again, Thank You for your time and effort making this process available !
Made the update and it was very straightforward.
But, while the CMU is now 11048, the TCU is still v10008. rbender reported his TCU was updated to 10024.
Is this something i should also update and where would be the source for the update files?
unless you have opted out of the infotainment data collection you dont really need 10024
TCU updates are related only to the connected services setups
I recieved the TCU and CMU update files and instructions for each from Ash8. I still use the connective services and everything has been working as it should.
Received the TCU files and updated to TCU 10024 today. I use the MyMazda app. Haven't tested yet but don't expect any issues.
Dont know if its my imagination, but the infotainment system seems to respond a little faster.
CMU_7000C0A-EU03_10030.kwi * CX-5 for Europe/UK with 10.3 inch screen ONLY.
Just Released
Changelog
(Ver. 7000C0A-EU03_10030)
• When using navigation with heading up mode, the vehicle icon may rotate instead of the map.
• When operating audio source screen, the system may reboot.
• If another incoming call comes in while ending a hands-free call, it is automatically accepted.
• While playing audio tracks using CarPlay, it may stop playing.
• While playing audio tracks using CarPlay, it may mute the volume.
• Beep sounds after every couple of minutes.
• Traffic Sign Recognition system (TSR) may not show correct speed limit.
• While playing audio tracks using CarPlay, when refusing the incoming call, screen shows “Phone in use” message and it stops playing audio tracks.
• When pressing the mute button, the audio track may not pause.
Mazda Connect FIRMWARE Update for all CX-5's and CX-9s from late 2021 (2022 MY) with 10.25 Widescreen Display ONLY.
Mazda has introduced (June this year) the latest Firmware Update for Mazda Connect and ONLY for models with 10.25 inch Display.
NA03_11048
ONLY NA03 is suitable for this model and the updated Version Number is 11040.
NA03 is ONLY for North American SOLD Models.
To find out what version is in your car now do the following..
GEN 7.
1. Turn the ignition to ACC or to ON.
2. Select ”Settings” on the Home screen.
3. Select “System Setting”.
4. Select “System Information”.
5. Select “Version Information”.
6. See 'System Software'
Version Number like 11007 is revealed.
IF your CX-5 is below 11048 Version Number I strongly advise you get your Mazda Dealer to update or you can do it yourself and yes I can provide you with the download link and the easy update on how to, this Genuine Mazda information will not be posted publicly you must ask for it in the form of a direct message stating all the detail that you find above (Current Region and Version info). IF you want your Mazda Dealer to update you MUST complain to them that you have an issue like Infotainment reboots all the time.
This is the changelog list of all the update fixes for NA03. (North America)
• No Changelog issued by Mazda.
Ver. 7000C0A-NA03_11040)
(Ver. 7000C0A-NA03_11038)
(Ver. 7000C0A-NA03_11032)
• Update detail screen shows incomplete sentence and trying to scroll to the beginning of the sentence leads to the whole sentence disappearing.
• Turning the main power off may lead to a reboot while playing audio tracks using Android AutoTM and displaying the map using Android AutoTM.
• DTC for disconnection of the mic may be stored in the CMU after updating the emergency call unit (TCU in MDARS) software.
• If the volume knob is pressed and held to turn the power off while adjusting Fader/Balance, the lines showing current setting for Fader/Balance may not appear the next time the power is turned on.
• Track selection using voice command may result in the error message “Too many tracks. This function is not available”.
• After selecting certain speed for the speed alarm, re-opening the screen shows default setting instead of the selected one while multiple USB devices are connected.
May I please receive the newest update files? I'm new to the forum, but have a 2021 CX-9 and CX-5 with 10.5" screens. Nearest dealer is 2hrs away. I appreciate it!
anyone knows if any update enables HUD navigation reading from CarPlay/AndroidAuto?
or if this is ever going to be implemented for CX5? (it's there in CX50)
Status
