How do you change the battery in the key fob? I have a 2020 CX-5 GT and I can’t find anything in the owners manual regarding this. Any help is appreciated!
Yes, that’s helpful…thank you! Quite the process…you basically have to disassemble the whole thing!This should work:
Mazda 3 Smart Key Fob Battery Replacement - DIY
2032 Battery you need - https://amzn.to/4tVKpnj2019 MAZDA 3 SMART KEYLESS REMOTE FOB FCC ID: WAZSKE11D01here is a video showing how to open up the new 2019 M...www.youtube.com
If only they had micro usbs for charging.This adds a layer of complexity that simply isn't needed and would probably annoy a lot of people.
That would be interesting. My ancient 2006 BMW Z4M has a rechargeable key fob. It uses induction charging while in the ignition. It is an issue with cars like mine that are rarely driven. Keys will die and the battery goes bad. I recently found it is possible to recharge the key using my Philips toothbrush induction charger. It would be cool if Mazda made it a rechargeable battery.If only they had micro usbs for charging.
The key fobs on my 2000 BMW 528i has the same rechargeable key fob using induction charging while in the ignition. Luckily both key fobs have never run out of the electricity even though we rarely drive the car.That would be interesting. My ancient 2006 BMW Z4M has a rechargeable key fob. It uses induction charging while in the ignition. It is an issue with cars like mine that are rarely driven. Keys will die and the battery goes bad. I recently found it is possible to recharge the key using my Philips toothbrush induction charger. It would be cool if Mazda made it a rechargeable battery.
Disagree. The masses will just keep them on the charger when its not needed and that's what degrades battery performance and why most people have dying/dead batteries with their cell phones quickly.If only they had micro usbs for charging.
I always wondered why my old E46 BMW's key fob lasted forever.The key fobs on my 2000 BMW 528i has the same rechargeable key fob using induction charging while in the ignition. Luckily both key fobs have never run out of the electricity even though we rarely drive the car.
I definitely will try to charge the key fobs with the Philips toothbrush induction charger.![]()
