So far nothing. Only drove home from the shop with full load of my 20s in the back. Shouldn’t have any clearance issues from my understanding.Nice setup! Those are some of the biggest diameter tires I've seen, at 29.5". Any rubbing?
Sweet! Yeah should def be ok with 38 offset. Figured 245's should work even if keep the 45 offset. 245 is just slightly outside the range. Improved handling? Any noticable negative performance, or acceleration issues at all?So far nothing. Only drove home from the shop with full load of my 20s in the back. Shouldn’t have any clearance issues from my understanding.
No clearance issues. Acceleration from a stop is slower and the steering response isn’t as nimble as expected. I have the turbo so acceleration taking a little hit is ok, and I haven’t driven hard like I did previously yet with my 20s so I’ll report back how the handling is later. Overall I’m very happy with the set up.Sweet! Yeah should def be ok with 38 offset. Figured 245's should work even if keep the 45 offset. 245 is just slightly outside the range. Improved handling? Any noticable negative performance, or acceleration issues at all?
Am trying to decide on 235(closer to stock) or the 245.
Hmmm. Good to know.No clearance issues. Acceleration from a stop is slower and the steering response isn’t as nimble as expected. I have the turbo so acceleration taking a little hit is ok, and I haven’t driven hard like I did previously yet with my 20s so I’ll report back how the handling is later. Overall I’m very happy with the set up.
Thanks for posting. I'm planning to go to a 19x8 wheel also, though I'm planning to keep the OEM tires for now, and eventually go to 235/50 when the Toyos need replacing. I appreciate the info. Cheersalso, if anyone is wondering, the stock 19" rims from 2021 MY are 30lbs and 225/55 Toyo tires are 29lbs, for a complete wheel weight of 59lbs. These BBS R3 rims are 22lbs and Conti 235/55 tires are 28lbs for a total of 50lbs. So, I reduced the wheel weight from 59 to 50lbs. Sounds great. Do I feel the difference? Nope, to be honest BBS rims are 19x8" +47 offset, Stock rims are 19x7 +45 offset.
Nope. Everything's stock. I won't be using this kit it was just a test fit for a week. I'm heading for 19x9 +45. It gives a perfect flush fit with the fenders with 255/50R19. I'll be using my Performance Pack wheels from my Mustang. The ones on the pics are Mustang PP2 wheels replicas.Thanks for posting. Did you have to make any modifications to accommodate the wider set up?
Thanks, that's good to know. I'm planning to stick with the oem tires for now but use 19x8 wheels with +35 offset. According to willtheyfit.com, that set up should match yours pretty closely as far as far as alignment with the fenders is concerned.Nope. Everything's stock. I won't be using this kit it was just a test fit for a week. I'm heading for 19x9 +45. It gives a perfect flush fit with the fenders with 255/50R19. I'll be using my Performance Pack wheels from my Mustang. The ones on the pics are Mustang PP2 wheels replicas.
Problably. My 19x10+35 are 1½ inch out of the fenders. With an 8 inch large wheel it should be very flush or just a tiny bit inside. It will be 10 times better than the stock look.Thanks, that's good to know. I'm planning to stick with the oem tires for now but use 19x8 wheels with +35 offset. According to willtheyfit.com, that set up should match yours pretty closely as far as far as alignment with the fenders is concerned.
can we get a side pic to see how flush they sit. I’ve been looking to run a 19/20 x9.5 35offset. Want to see how far/wide I can push out before it pokes out. I’m lowered on corksport springs with a bit of camber so it might help
