100K MP5 Club
We just broke 240,000 and still going strong. Just have to take care of it. His name is Charlie and he may be on the market soon for any MP5 fans out there!
1) Keep on top of your maintenance
Change the oil every 3500-4000 miles
Check the oil every time you fill up
for automatics - drain and fill the ATF every 15k miles and change the filter every 4th time
2) When the CEL comes on - diagnose and fix it ASAP
3) spray fluid film or corrosion X-HD in every nook and cranny, seem, and exposed metal underneath the car - every other oil change
My commute isn't very long and the wife says we aren't allowed to take it on any long trips due to how rough it rides, how its broken down in the past, it's mostly rust, etc. Women and their grudges, amirite?
Plus I just bought this for our roadtripping. 2003 jetta tdi, manual.
Hey we have the same color p5! Wooo!
3 months of ownership of my White, manual trans, no option, 303,000 miles on 2002 P5 acquired from original owner in North Carolina. New to Mazda & Love it! Analog ICE car in world about to go electric. Just did by myself & 19 yr old: timing belt, vbelts, tensioner/idler, H2O pump, valve cover gasket/PCV, exhaust gaskets, control arms sway bar links and tie rod ends, Brembo brake pads, StopTech vented rotors. Has KYB but clunking. Working w AWR on making Koni inserts to go with Racing Beat coil springs. Goal is streetcar for Autocross/ local milk run car. Any suggestions on straight-pipe options for the 2nd cat replacement? Or simple rear muffler options? Any suggestions for best summer tires for 195/60R16?
Just passed 300,000 miles. Still on the original clutch; I just had the radiator replaced, though. It uses oil - but not too badly. I bought some blue stuff that really helped seal the rings and pistons so it doesn't smoke so much on start-up. Had my share of brake issues, and I CANNOT seem to figure out why it pulls to the right on the steering! But overall, what's not to like? Fun car to drive, gets good mileage, handles like a go-kart and still capable of high speeds.
Just passed 300,000 miles. Still on the original clutch; I just had the radiator replaced, though. It uses oil - but not too badly. I bought some blue stuff that really helped seal the rings and pistons so it doesn't smoke so much on start-up. Had my share of brake issues, and I CANNOT seem to figure out why it pulls to the right on the steering! But overall, what's not to like? Fun car to drive, gets good mileage, handles like a go-kart and still capable of high speeds.View attachment 301115
Mine is screaming at me at over 4K RPM by the time I get up there. Anything above that sounds absolutely terrifying.
300K is quite a milestone, are you the original owner?
