GatorBait1996
Hello All, I recently changed the oil in my wife's 2011 CX-9, I purchased the Fumoto F107N per Fumoto's website. Since changing the oil she has driven it to work a few times and says the oil light on the dash comes on once the engine warms up, it 1st flashes then stays on. My only thought is the Fumoto valve, since I have changed the oil in that vehicle several other times but used the original drain plug. Has anyone else seen the Fumoto valve cause an issue with oil pressure, is it possible that the Oil Pressure Switch has gone bad and just a weird coincidence??
I went to her place of work when she 1st told me about it, to see if it were low in oil, it was not, oil was right at the line, I added a little more to be right in the middle of the Min and Max lines, still has the same issue.
I'm thinking about changing the oil again and replacing the Fumoto with the OEM drain plug to see if that is what caused it.
