CX_MCHNE
Thread Necromancer
- CA
- 2019 GTR
Sadly, I never learned to drive an automatic. Any tips for being quick off the line w/ a GT-R?
What I've tried:
I'm worried I'm going to burn up the clutch or break something if I just start trying stuff. Thanks for any advice!
What I've tried:
- Brake to a stop
- Switch to sport mode (tach just hangs there limp at 600-800)
- Switch on auto hold
- Hover my foot over the gas pedal
- When the light turns green, immediately fully depress the gas pedal
- Should I try holding it at 2500 and dropping from neutral to drive?
- Is there a trick, like turning off traction control, to tell the transmission I want to launch the thing?
- Is there a way to use the manual gear selector stick for quick starts?
- Should I pull the flappy little plastic parking break switch into the mix?
- In my last turbo, holding revs up while stopped didn't seem to build much boost; should I be doing that?
