- RDX Aspec Adv.
Why the spoiler? Does it actually do? Meaningful? Compared to Mazda's airflow plan?
Chris, do you have a tutorial on how to remove front and back Mazda emblem? I'd like to plastic dip mine too.
As far as I'm concerned it's only aesthetic. The oem doesn't make any claims otherwise. https://www.autoexe.co.jp/english/car/ke.htmlWhy the spoiler? Does it actually do? Meaningful? Compared to Mazda's airflow plan?
You have an awesome car, but if you're going to 'use' it on the public road, drifting, etc, you are an asshole. Most of the time I have my 2 year old daughter in the back of my car and encountering you 'drifting' on the road would not be my idea of fun.
Go to a track.
No. There may be something already on the forum though. The front is just plastic clips so you need something to pry and the rear is adhesive.
Got my Crystal Eye LED's. Was going to wait to install them but I wanted them on now. I'm debating if I want to dip the bottom reflector, or I may just put some tint over it, which I got cheap on ebay. The lights have been wired into the third brake light, otherwise they won't brighten when you touch the brake. Very simple to install, the brake line was just an issue of wiring tapping, not much unlike installing dual horns (pre 2016). Only tools needed are a 10mm socket and a flathead for prying. Also at the same time the Whiteline sway bar brackets came, and the camber gauge now I'm just waiting on the coilovers to come in the mail.
Hey man, love what you've done with CX-5. I got similar taillights off E-bay for a great deal, but the connection for the reverse lights was not long enough to reach, so I had to return it. Where did you get yours from and does it pass Texas Inspection with no problems? Was always told that the rear lights have to have a red reflector? Thanks in advance.
I really dig the sequential turn signal.
I had an idea long time ago, which I think it is a good one, to have sequential brake lights as well. More pressure you apply to the pedal, more Leds would turn on. The min and max limits Leds would be on all the time.
Installed New rear LED taillights from Japans. They have sequential (selectable) blinker.
Care to share a link to said product?![]()
Hmmm, I saw this the other day.
https://www.vividracing.com/tuned-ecu-flash-tune-mazda-cx5-25l-skyactiveg-190hp-p-152430527.html
Are you aware of anyone using this on their CX-5?
