I added a shift panel cover today to cover up some of the piano black plastic. The piano black had a few scratches after I glanced at it wrong.
Are those scratches between the switches?
Where did you buy these covers? Looks good.
Unfortunately, yes.
The stainless steel piece for the right front door does not come with an opening for the window buttons. During the process of cutting the hole, my Dremel slipped twice.
I will probably get a new one and try it again.
Yep, I sped up to avoid him when I saw it. I was turning left at an intersection and I had the green light. Didn't speed up quite enough and he clipped me....and ran.That sucks.
The greatest danger in the snow is the other guy.
Installed my brake rotor/pads ($136usd from ebay) and changed the oil.
Which kit? Brake Motive, eLine, Ect.
	Buy the fender trim (less than $50 at Med Center), do as said above to the paint, and see what you think. I think you'll be quite surprised at the results and keep the $1k in your pocket...
I guess you could price the bumper trim ($200ish is my guess) and get it to0. Both are easy installs. The little gap or whatever you're seeing will push out when you put the fender trim back on. It's pretty loose to begin with as it has some room to move already. Either way, I'd do all this before dishing out a $1k and having my whole bumper and rear fender painted, and an insurance claim on a 5 year old car to boot.
Good luck, it sucks no matter what. Sorry man!
