- 2014 QX70 AWD
They look like the pizza wheels but without the accent color.
Much better looking and with a slightly different surface/face.
Pfft. Cleveland pizzas the best. Second is Chicago. Then NY.You could probably say that about most wheels...slices of π
All good if the pizza comes from NY[emoji41]
A Clevelander is a cross between a NY and a CHI. Thicker than a NY, thinner then a deep dish with that pie tasting kind of crust. Toppings on the bottom, sauce on top. To die for!
Added some clear bra to the A-pillars. Already got a couple rocks chips in one of them. May do part of the hood next.![]()
I bought one of those cheap Swifter dusters with a disposable head and dusted the dust off my car. The duster is very soft, it won't make micro scratches.
I would not recommend those.. while both will push around/pick up dust and dirt, they simply trap it in the fibers. Even if you shake it out or try to vacuum the dust out, some dirt will remain and it will eventually cause swirl marks.
One of my hids was blown so I replaced them with some d4s 5500k i got from morimoto. The design of the spring clip holding the bulb from moving around is horrid.. they pretty much are out of shape after you use it twice. And you have to at the least partially remove the bumper to get the light out to do it.
No. All I ordered was a bulb (D4S). my car already has HIDS factory. The spring retaining clip is part of the oem assembly. Light output is good. Mazda uses OSRAM oems. I got 5500k which are a little more yellow than I expected but the output is very good. https://www.theretrofitsource.com/d...43ztNfWthGEbkiFBVxM5KvpGKM8G0KEBdwxkyK29XrC1IIs that an oem part of something that came with the Morimoto kit? Also How's the light output? I know Mazda uses environmentally friendly HID bulbs.
