- Canada
An "all-in-one" thread is a great idea, since the system is the same across all models (right?). Even then, with all that information in one spot, it would be just as confusing as this thread.
If you want to make it Google-friendly, separate the topics into their own threads. That way, a Google search for that topic brings up the thread dedicated to that topic. Less "extra" stuff to wade through in that case.
That said, I don't think it's all that necessary since you can just use the "Search Thread" feature located right above the first post of any page. Typically, when I want to find some information/feedback on a discussion forum, I do a Google search to identify relevant threads from different forums. Then I use each forum's Search Thread tool to find what I'm looking for. If I can't find that info (usually due to the forum's Search Thread tool not working correctly), I post a question stating that I've tried doing my own research already.
If the "Google it" response bothers you, this is the best way that I've found to avoid it, as you either find what you're looking for in the process, or you show that you've done your due diligence before posing the question.
