Trivial question
Did you foam in the driveway and then pull it into the garage. Must have or you have some very good foaming skills.
I foam and wash in the drive early before the sun is a factor and just about have to use the pressure washer to break up the dense foam and move it off the drive. Other times for a quick wash I will wait until 5 PM when shade is cast on the drive for a foam and two bucket wash.
I often talk detailing with a coworker and we wish we had a large open garage like high end pros so the entire process could be done in good lighting and not in the sun. I start early and try to get past the decontamination part with Iron X and then pull it into the garage for the rest, but I have to plan it by setting the alarm for an early rise and go at it fast. Once I get to the point where surface temperature is important I will pull it into the garage, take a lunch break and let the paint cool. With both of our cars being white they cool very fast.
Your CX-5 paint looks great and so does the 4Runner.
