definitely due for an update. i ended up removing the 440cc injectors for now and may revisit them later. much rather enjoy the car rather than stare at it and scratch my head at it all summer. for some reason, after resetting my ecu and reloading my fuel map, the car would run awesome and have the proper AFR for about 3-4 days. during that 3-4 days (even without adjusting my tune, trust me i've tried), it would peg 10.0 under wot. changing the map once this symptom started didn't ever make a difference ever. put the stock injectors back on and loaded the superstock map and the car runs awesome. i'll leave it as is for the time being since adulting has been taking up most of my time.
only issue at the moment is the car developed a weird rattle that resembled the sound of an exhaust heat shield around 900-1100 rpm that seems to be coming from the front left side of the car. having the ac on at idle would sometimes rev the car up just enough to trigger the sound as well. rattles while at a stop, moving, clutch in, clutch out, braking, not braking lol. it's somewhat driving me nuts. once the car is revved over that specific rpm while stopped or moving, the car operates as normal. i've been under it twice with it idling and the ac on and couldn't pinpoint where the sound is coming from. couldn't find anything loose. it sounds loudest near the area of the trans and intake mani from under the car. looking under the hood you don't hear it at all. i'll have to bring it to a friend to have him take a look see when i get some time.
